[QUOTE=Bill Dearborn;1577080841] If it ain't broke don't fix it. A little bumping on a cold shift doesn't indicate or even come close to indicating a problem with a transmission. I started at the beginning of this thread and I think the OP was a victim of being anal and complaining about a non problem, which got him involved in a violation of the "if it ain't broke, don't fix it" law.
Bill[ I was also going under the ".....if it ain't broken rule also..... for a few months of grinding fifth gear....but as others have said...what's to worry if it is a warranty.....now I can feel relieved and get on with it....and hopefully with no further grinding or bumping.
Originally Posted by FastestBusaAround
(Post 1577086875)
I had my 5th-6th gears and synchros changed under warranty because of a 5th gear grinding as well...
Warranty item........ and life is good:flag: |
I must have been blessed with a good one. I have no issues. 21k miles.
My '08 has been grinding when performing a high RPM shift from 1st to 2nd since the day I bought it. Hundreds of other people have had this problem too, and it's been going on for YEARS. Has anyone figured out what the problem is, or do we just have to live with defective transmissions forever??? :ack:
It appears that this should be a "Sticky" thread.
Mine is a 08 and I get a little metallic growl on occassion taking off in 1st. I believe this is clutch related.
Originally Posted by Mopar Jimmy
(Post 1577111873)
If you in the market and are concered about it stay away from an 08 Z, the issue was fixed in 2009, nor did it exist with the battle tested T-56 trannyd used in the 06 and 07 Zs.
My 07 has been at the dealer for 3 weeks with them waiting on t56 parts or a new tr6060. The mechanic said my tranny was hot. I guess that it had a burn in it. I find it hard to believe that dealers can't get parts or a new tranny because none are available. So my wait continues
Is it reasonable to expect a low to mid mileage '08 would have already had this issue come up and corrected by an original owner if it were going to happen? I am in the market for an '08Z.
I have test drove two looking for this issue. Is it only apparent at a high RPM shift or can you feel it just rowing through the gears while the car is off? |
my 2012 has the same issue, i would consider it normal as my 2008 was exactly the same. i would not put any concern on this subject.
it seems only apparent when the trans is cold and your driving normally. i think by the time most people are ready to romp on the car, they have already gotten the engine to operating temp and the issue is gone by then. fyi i have heard of several people changing out the manual trans fluid to something different with good results. i would do a search for that and plan to replace it if you think yours has any issues. |
Is there an easy visual clue to seeing if I have a T56 or a TR6060 in my 08 Z06. I had it in the other day to install my ackrapovic exhaust in a Corvette performance shop and he said I have a T56, there was nothing on the GM vis when I bought the car. No problems with the transmission though..shifts great.....just wondering...??
Originally Posted by m.whitmell
(Post 1580384471)
Built
Is there a 'built TR6060' version that is for over 600rwhp and will not carry over all the issues the stock one has? I have a 08 H&C, Stroker getting ordered mid April.
Originally Posted by Lethal427
(Post 1580385790)
(Post 1580385790)
