Replaced A6 trans, now car will not start
ok, car blew up the trans... I went and got a trans from a member o the board out of a matching year (2007) car, now the car will not start..
It is not the battery, the car is recognizing the fob, but it is not cranking.. it shuts everything off, and you can here the T/B move, and it has fuel pressure, but nothing.. Any ideas would be great thanks.. Do you have to re flash the ecu (hp tuners) to get the car to recognize the trans? |
I would check the neutral safety switch. It might need adjustment. :cheers:
if you move the shifter out of park, it tells you to put it back in park like normal...
Since there is a seperate Transmission Control Module in the Transmission you may have to have a tuner to "introduce" the new TCM to the ECM?
Chuck @ Corvettes of Westchester can probably answer your question. |
Originally Posted by VET4LES
(Post 1567144724)
Originally Posted by danl72
(Post 1567147028)
:iagree: Try that first.
Swap your TCM from your old A6 or have the new one tuned by Chuck. Mine did the same exact thing when the main harness plug was not fully plugged in so the PCM must not be recognizing the TCM. Just my .02.
My removal thread should help you if you decide to pull the TCM. http://forums.corvetteforum.com/show...465&highlight= |
THANKS GUY"S!!!!!!!!! please keep this coming,, anything you can come up with? tell me.....TTT
Hey man......
Originally Posted by craftfox
(Post 1567143898)
It is not the battery, the car is recognizing the fob, but it is not cranking.. it shuts everything off, and you can here the T/B move, and it has fuel pressure, but nothing.. Any ideas would be great thanks.. Do you have to re flash the ecu (hp tuners) to get the car to recognize the trans? Chuck CoW |
