Air Conditioning a C1
Probably a frequent ask question but being a new C1 owner I don't get on this forum much. Anyway I just bought a 57 that is under construction. It was a old race car and only has 58K on it, It will be a resto rod with Fatman suspension, blown 355 etc etc (Please not flaming):rofl: My wife wants air in the car so I gotta get it. Which manufacture has the best unit for the C1? I had a Vintage Air in a street rod and was well satisfied with it but wanted to check with the experts first (you guys):cheers: to see which one you liked. Thanks for the info.....
Originally Posted by Low Rider
(Post 1566363113)
...I haven't made a choice yet but I am seriously considering this because the case is screwed together rather than glued and repair parts can be bought and replaced...and it has a large evaporator (they call it an a/c coil). Also the system is controlled using the original heater control panel for all of the air diverter doors and air temperature changes. http://www.classicautoair.com/Corvette.asp Good luck...Stan.. |
Hot Rod Air... somewhere on here is a thread about mine and others install...
here it is.... http://forums.corvetteforum.com/show....php?t=1540091 Bill |
I have the Classic Auto Air unit on my '56 and have been very happy with it ...
Originally Posted by 56 Texas
(Post 1566368373)
Hey thanks guys, I will check out each suggestion and I am sure I will have more questions on other stuff:D as I said I purchased the car in process but paid to have it completed so I got lots of questions.:eek:
BTW from looking at you avatars you have some way cool cars there..... |
(Post 1566368642)
Classics intro sheet on their web site only shows 58-62? Do they actually have a unit for the 56-57s?
I have wanted air in the 56 for many, many years, but I just haven't been able to do the mods to the car. Also, I DO NOT want to eliminate the stock, factory 56-7 heater system, so if I were to add air, I want an air ONLY add on system. One last thing, I want to retain the "original" look of a generator. There is a guy in Tex who can supposedly modify a generator to put out about 40amps, which should be adequate for an add-on air system. So, why don't I want to convert to an alternator? Like I said, I want to retain the look of a generator. :thumbs: |
DZAUTO perhaps this would help someday. It looks like a generator but is an alternator. Save the Wave.
DZAUTO, oops I forgot the link. http://www.gener-nator.com/ Save the Wave.
(Post 1566363113)
(Post 1566368642)
c1 corvette air
we put a unit from southern air aka southern rods in my 61 vette .small block with blower .worked great with no overheating and it gets hot in south florida.the secret is have a good quality rad/fan set up and use a condenser/fan assm. remotely in rear above the axle (there is room) we had a narrowed 9 inch .if this is attempted condenser cannot be flat has to be on an angle .unfortunatly no pics of underside car has been sold and went to texas.oh and also use the best a/c hose you can buy i heard there is a grey hose that is used in buses because of the length cheap hoses will have you recharging every 2 or 3 years.good luck
Low:
Congratulations on your new project. I used Hot Rod Air and am happy with it. However I never run with the top up unless it is raining. In retrospect I should have put the money into restoring my hard top. I suggest you consider insulating the heck out of the interior. I installed Dyna-Mat inside of the car from the windshield retaining bolts, down the firewall, along the floor and up behind the seats. I'm in a cocoon of Dyna-Mat. It is rubber based, does not absorb water and installs almost too easily. By that I mean once you peel the paper off of the sticky side make sure you place it where you want it. There is little or no adjustment once it sticks. A fabulous side benefit is that it water proofs all those little holes and seams we all have in our floors and fire walls. I get no water during rain events except from my windshield convertible top joint. It keeps the road heat away from you as well and deadens the sound making the car a pleasure to drive. Best Regards |
