Ever have to change the fuel filter in the C6?
Do you ever have to change the fuel filter in the C6? Isnt it located in the fuel tanks so how would someone change this without having the dealer do it?
Originally Posted by biskitman
(Post 1566297972)
I dont understand why a fuel filter would be placed in the tank and not along the fuel lines where it's easier to get at like other cars.
Guess the dealers just want you bringing it in if it needs changing. |
A lot of GM cars are going to the filter in the tank. Some have an access panel from the trunk to make it easier.
Originally Posted by talon90
(Post 1566298055)
The fuel filter is not considered a maintenance item. It is actually inside the fuel tank and is quite an ordeal to remove it. You should not have to replace it under normal circumstances.
1 Attachment(s)
Originally Posted by FloydSummerOf68
(Post 1566298087)
Guess the dealers just want you bringing it in if it needs changing. Attachment 48162973 (1) Fuel Fill Hose (2) Left Fuel Tank Grade Vent Valve (3) Fuel Feed Pipe to Engine (4) 5/16 Inch Auxiliary Fuel Feed Pipe (5) 3/8 Inch Auxiliary Fuel Return Pipe (6) Right Fuel Tank Grade Vent Valve (7) Fill Limiter Vent Valve (FLVV) (8) Secondary Fuel Pressure Regulator (9) Siphon Jet Pump (10) Convoluted Crossover Hose (11) Anti-siphon Hole (12) Fuel Sender Reservoir (13) Turbine Fuel Pump (14) Venturi Pump (15) Primary Fuel Pressure Regulator (16) Reverse Flow Check Valve (17) Fuel Filter Here is the note on changing the fuel filter: Fuel Filter The fuel filter is contained in the fuel sender assembly inside the left fuel tank. The paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement. |
I dont care if it has to be changed rarely...when it DOES need to be changed you're screwed.
What a pain in the arse!
You would think they would have an inline filter like trucks/SUV's. ~Brian |
I can't believe that! What a pain I figured it would be like the C5:willy:
1 Attachment(s)
(Post 1566299820)
Attachment 48162972 The C5 used a different system which was inline in the fuel feed pipe ahead of the injectors. Not sure what prompted the change. I don't know of many that needed to change the in-line on the C5 and time will tell on what needs to happen on the C6. |
Never have and don't plan to. Too much work. Just think when these cars get old and the next generation of restorers have to do this !!
i probably won't own the car long enough to have to worry about a fuel filter :lol:
This is amazing. There should have been a filter in the line between the tanks and the injectors. I have always made it a point to change the fuel filters in my cars once a year.
This is why I only use top tier gasoline and a fuel system cleaner prior to each oil change. (once a year).
GM needs to realize that many Corvette owners need to tinker. Changing a fuel filter once in a while, whether it needs to be changed or not, gives us a great sense of satisfaction, not to mention the performance gains!
My wife's previous car, an Audi A4, leaked every possible fluid. Every couple of days, I had a job to do - get that car roadworthy and keep my wife safe. A few weeks ago I bought her a Cadillac STS. Now I have nothing to do. I feel so useless! |
Most GM vehicles are going to this system with the filter in the tank in my experience you will need to change the fuel pump before you need to mess with the filter, I think they are meant to be changed as a unit. Bye good quality fuel and you should not have an issue.
I've had a lot of cars in my life. I cannot think of more than once or twice in my life that I have really had to change fuel filters and that was in old beater '48 and '50 pickups.
(Post 1566299983)
Yes you would be. The removal of the tanks is a bit of a challenge. This assembly resides behind the seats:
http://img.photobucket.com/albums/v6...algastanks.jpg The C5 used a different system which was inline in the fuel feed pipe ahead of the injectors. Not sure what prompted the change. I don't know of many that needed to change the in-line on the C5 and time will tell on what needs to happen on the C6. |
2 Attachment(s)
Is it really necessary to remove one or both of the tanks to change the filter? Looks like a body panel and then go to the top of one of the tanks...based on the illustration.
Attachment 48157330 Attachment 48157331 |
Originally Posted by AORoads
(Post 1566300049)
fuel filter in the tank for Corvette has been since the C4! but then, it was about an hour to slightly more to do.
<snip> Fuel filter rode inline near/above the cat mounted on the passenger side frame, there was a heat shield. Changed enough of them to know. Now, there may have been one in the tank as well, but in almost 500,000 miles (four cars) I never had to change one. |
