ok im lost - program spare key fob ?
i bought a num 1 key fob on ebay with instructios,but they dont work,i have an 05 with push button ignition with a working number 2 ,,,please guide me ,,,thanks guys tony
Method 1 - Key Fob Quick Learn
This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key. Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance. 1. The vehicle must be OFF. 2. Open the rear compartment. 3. Place a known key fob within the interior of the vehicle. 4. At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. 5. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). 6. Place the replacement key fob in the glove box fob pocket with the buttons facing right. 7. A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED. 8. If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode. 9. Operate the active portion of each key fob to exit the programming and to verify correct system operation. The number on the fob doesn't have anything to do with Driver Number. If you are wanting to change your fobs so that Fob 1 corresponds to Driver 1, I believe you will have to go to the dealer and hook it up to a Tech II. Method 2 - Key Fob Slot Programming This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool. Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance. 1. The vehicle must be OFF. 2. Open the rear compartment. 3. Place a known key fob within the interior of the vehicle. 4. At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. 5. Install a scan tool. 6. Use the scan tool, to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Replacement/Setup • RCDLR • Program Key Fobs 7. Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to. 8. Place the replacement key fob in the glove box pocket with the buttons facing right. A beep will occur indicating programming completion. The previously known fob is now erased. 9. If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming. 10. Remove the scan tool. 11. Operate the active portion of each key fob to exit the programming and verify correct system operation. |
The fob that you have that is not yet programmed for your car can only be programmed as a #1 fob or a #2 fob by using method 2 in the post above by 2000C-5. YOU MUST PROGRAM BOTH FOBS, even the one the car already recognizes, when you use that procedure.
If you screw it up, it's possible you could wind up with no fobs that will start your car and your car would have to be flat-bedded to the dealer to fix it. |
Originally Posted by 2000C-5
(Post 1566242807)
This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key. Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance. 1. The vehicle must be OFF. 2. Open the rear compartment. 3. Place a known key fob within the interior of the vehicle. 4. At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. 5. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). 6. Place the replacement key fob in the glove box fob pocket with the buttons facing right. 7. A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED. 8. If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode. 9. Operate the active portion of each key fob to exit the programming and to verify correct system operation. The number on the fob doesn't have anything to do with Driver Number. If you are wanting to change your fobs so that Fob 1 corresponds to Driver 1, I believe you will have to go to the dealer and hook it up to a Tech II. Method 2 - Key Fob Slot Programming This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool. Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance. 1. The vehicle must be OFF. 2. Open the rear compartment. 3. Place a known key fob within the interior of the vehicle. 4. At the rear of the vehicle insert the vehicle key in the rear compartment lock cylinder located in the lower left and cycle the key 5 times within 5 seconds. 5. Install a scan tool. 6. Use the scan tool, to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Replacement/Setup • RCDLR • Program Key Fobs 7. Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to. 8. Place the replacement key fob in the glove box pocket with the buttons facing right. A beep will occur indicating programming completion. The previously known fob is now erased. 9. If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming. 10. Remove the scan tool. 11. Operate the active portion of each key fob to exit the programming and verify correct system operation. let me tell you guys something, I went to a Chevrolet Dealer with my 08' C6, to get 2 new keys and keyfobs. I went to the parts department and ordered 2 key fobs and keys, when they came in, I went to pick them up, and made a appointment with the service department. The next day, I went to the service department at 8 O'Clock. The service technician told me that I couldn't use the new 08 FOBs, and needed to use the old FOBs. I was surprised... So I exchanged one of the 08 ones for a older version, but kept one of the new 08's because I had a hunch it could work.. So I had to come in again at 11:00, because they had to order the FOBs. Then after a hour and a half of waiting, at 12:30, the service tech told me that. "their programmer was malfunctioning, it says its okay, but then it doesn't work", and told me to, "maybe call us tomorrow and see if its working, or you could try another chevrolet dealer'. So I went home, having wasted a lot of time. Then I went on Corvette forum and found your post, followed it. and programed both my new keyfobs. the 08' version and the old version... all by myself. It's pretty ridiculous that the service department of a Chevrolet dealer can't do what I just did by just following some very very useful instructions.. |
Originally Posted by JimTN
(Post 1566243521)
got it
it worked ,thanks im loving this c6
My DIC will not display anything when I cycle the key. I've followed the instructions so I don't know what I'm doing wrong. I'm trying to just re-program my #2 FOB.
Originally Posted by Beatitt
(Post 1566369224)
Originally Posted by Sonic03inSC
(Post 1571029755)
Same issue here, anyone help?
http://forums.corvetteforum.com/1570351932-post19.html Cheers, Kent |
subscribed
Originally Posted by Barzten1
(Post 1571040884)
subscribed
Ed |
anyone know if the newer style key fob will program to my 2006
Originally Posted by bugzweiser
(Post 1573984765)
Start a new one.
