replacing inner fender liners
i posted here because this is the only section i go in. i damaged the rear quarter of my car and cracked the inner fender liner. so both have to be replaced. i am looking for a link to a writeup. i know they are glued on the frame. any help would be appreciated.
The rear fender wheel inner are NOT bonded in. They are held in with 8 screws. You can change them in about 1/2 hour easy.:cheers:
Are you talking about the wheel well liners? If so, they are help in by 7mm skrews
i need to replace the ones on the front too... i know they are glued and just assumed the rear were. thanks. what about something to replace the fronts
