1959/c1 vette parts
All these parts came off of my 1959 corvette or were acquired during the restoration, have pictures of all items available on request, all prices negotiable thank you
tach 6500rpm high lift cam tach $250 new tach face, chrome bezel, bezel retainer $325 with tach hood control assembly/release cable gm 1990911 for 58-62 vette $50 park brake lever used $10 front suspension lower inner shaft $60 56-62 soft top rear latch screw set 16pcs new $4 56-62 soft top rear latch gasket set new $3 58-62 master cylinder 150 2brl intake manifold gm20 #3840905 64-65 283ci $50 62-64 cylinder heads 3795896 d215 d235 $250 sbc chevy valve covers $80 bellhousing 3733365 gm8 ck128 $100 12 3/4'' flexplate gm14088765 153 teeth externally ballenced $50 14'' flywheel 8729004 k48 168 teeth $50 crankshaft pulley bottom 3756328 $30 crankshaft pulley top 3724815 $30 water pump pulley 3724816 $30 56-60 fan blade $40 58-61 tach cable new $20 heavy duty clutch fork most gm new $15 58-62 2 male hood lock assmeblies new $100 58-62 2 female hood lock bolts $5 58-62 2 park lamp lens bezels new $15 58-62 aftermarket gas pedal new $10 59 2 rebound straps with bolts and nuts not rivets $50 58-60 2 rear reflector assembly new $50 57-62 2 front sway bar bushing 1'' new $10 58-61 2 door open bezel on door panel $15 gm rochester 2brl carberator 7024110 $50 56-62 heater/defroster outlet molded plastic reproduction new $70 59 original hood in primer $700 56-60 copper/brass radiator small leak, one side bracket missing $150 53-62 rear spring used 5 leaf used $75 4 15'' steel wire wheel covers $75 61 grill damaged $150 56-62 original gas tank $200 |
I am interested in the following 2 items from your list. Can you tell me exactly what year the following assemblies are for?
58-62 2 male hood lock assmeblies new $100 58-62 2 female hood lock bolts $5 It is my understanding the "male" piece was changed in 1960 and works better than 59 and older. C Ya, Joseph Rock Frankenstein 59 |
Hello:
I will take the pulley crankshaft pulley bottom 3756328 $30 let me know shipping Thanks Billy the Kid :flag: |
are the rebound strap holes where bolts went thru now too large for proper rivits or are they still useable with proper rivits installed? james
Brain,
I have sent you two private message's. Are your parts still for sale? If so, please email me at gowerr@aol.com. Thanks, Rick Gower |
Interested in the 58-61 2 door open bezel on door panel $15
Please send pics to pfwhicker@comcast.net |
I would like the 56-60 fan blade. Is there a picture?
Could also use the bottom crankshaft pulley if you have another one. Tom |
"58-60 2 rear reflector assembly new $50"
Do these have 2 each of the bezels, lenses and mounting hardware? In other words, is everything there to mount them on a car? If they are complete, will you take $50 shipped to 27284? |
no reply yet.:yawn: james
sorry havent been online lately pics will be sent out to requests, the pulley is sold i'm posting all these parts for my father he's computer illeteriate so i have to go to him with all questions.
Do you have the 4 speed clutch fork for a 59 corvette ?
Please call me on my cell Mike 973-747-6234 |
Originally Posted by Michael 59' corvette
(Post 1578625629)
Please call me on my cell Mike 973-747-6234 I have the clutch fork, but if original poster chimes in, then I will bow out, giving him/her first right to sell. G 210 748 4693 geopar@gvtc.com |
Originally Posted by 1960fi
(Post 1578625941)
This thread is more than 3 years old---Original poster may be long gone?
I have the clutch fork, but if original poster chimes in, then I will bow out, giving him/her first right to sell. G 210 748 4693 geopar@gvtc.com How much for the fork & shipping ? |
(Post 1578630881)
