Loose Seat?
Fellow CF'ers,
I'm having an issue with my seat rocking a little back and forth under heavy acceleration or braking. Anyone else? I'm guessing it's just a loose screw or two under the seat but haven't found it yet. Can anyone point me in the right direction? I'm driving an '08 vert if that makes a difference. Thanks! Steve :cheers: |
Unfortunately, it's much more than a mere loose screw. You will need a new seat rail assembly. Had mine fixed by my dealer. The good news is that it's covered by your warranty. The bad news is that it may be difficult for them to find the parts.
When I first complained to my dealer, the response was, "This is normal." To which I responded, ":bs ! Fix it!:smash:" It took them a couple of days to find the parts. The first replacement rails were as bad as the originals, but the second set were just fine. :cheers: |
Known issue. Either run it all the way back if you have long enough legs or
http://forums.corvetteforum.com/show...ght=loose+seat John |
Thanks, guys!
Steve :cheers: |
Originally Posted by Res1cue
(Post 1565906196)
