Trunk doesn't close
I have an 01 Z and every once in a while when i try to close the trunk it doesn't want to latch. Some times it takes two or three tries before it latches. I notice that when i hit the trunk release button it sounds like the lock almost resets itself normally and then i know i will be able to close it. But when i don't hear that noise i know it's going to give me problems. So i don't know if it's electrical or the locking mechanism itself or what.
spray some wd40 on the latch and close it and open it a few times. the latch just may be getting stuck
Try closing your trunk with the door open.
Something if the car is closed up tight the trunk or hatch back wont close |
Originally Posted by AU N EGL
(Post 1565871702)
Originally Posted by DPG
(Post 1565872385)
:iagree: this can be it too. try it with the window cracked open
:iagree:
Trunk Latch
Hi,:iagree: wd40 on the latching mechanism should do it.
you have to stop putting those bodies in your vette....old lincolns work much better....:rofl: :rofl:
