How To install 2 bar map sensor???
Can some clarify for me the process of this. Do you have to plug the hole for the stock MAP and run a vacuum line to this new sensor? Then do you have to change the wiring up to accomodate the new sensor. I was going to order a 2 bar sensor but it appears that the sensor for the Meth kit is 2 bar so it should work right?
Also to clarify I have an extra meth kit Map sensor
If you have the correct MAP, it should replace the OEM MAP you have and plug right into that OEM harness. You will have to pull off the rubber boot and swap it out. But its plug n play.
The Meth MAP will plug into a manifold port and will have it's own wiring. |
where can I obtain the correct MAP sensor and does anyone have the part number?
Are you using the 2bar for tuning purposes or is this specifically for alky?
If for tuning, there is a plug ad play 2 bar but you will need a tune which is made for it. Arnel |
Allright, it sounds like you should keep the one you have in place and just add the 2bar for meth.
Do you have an electronic boost gauge? Some come with a map sensor or outputs and provide everything you need, voltage wise. Arnel |
Arnel its not for meth... its for tuning
I am wanting to go to a 2bar SD OS
Originally Posted by 95BlueBomber
(Post 1565590246)
LS1speed sells a pig tail that plugs into the stock connector for the stock map wiring harness. Just unplug the connector from the stock map and plug it into the new connector (pig tail) then plug in the other end to the new map. You will need to run a new vacuum line to the new map and plug it in. This is the way I did it with the 3bar map. You can leave the stock map in place...you are simply relocating the new map off of the intake manifold to an alternate location. or I believe GM sells a drop in replacement (but don't know for sure) that is a 2bar OEM part for the Cobalt. But as I stated I am not sure that it will plug directly into the back of the LSx intake. The remote option is very easy...probalby the easiest mod I have ever done.:lol: |
For up to 15 lbs boost - plug & play:
2.5bar:GM P/N: 12580698 AC Delco: 213-1631 http://forum.efilive.com/showthread....light=12580698 Kevin: That's looking pretty complete there buddy.. |
Originally Posted by AVB
(Post 1565591347)
2.5bar:GM P/N: 12580698 AC Delco: 213-1631 http://forum.efilive.com/showthread....light=12580698 Kevin: That's looking pretty complete there buddy.. Good reference (link) you provided Arnel. When is the next get together I am tired of just driving my car to work on occasion and giving people rides. I was thinking Vette Magic would be good, but if the weather (in June) is 100*+ out I have no desire to go to the strip and hammer on my car. Actually this weekend would have been perfect for a track day at Sacto. |
When I used the 2-bar sensor, I just plugged it in, converted to new OS and began tuning. I used the 2-bar sensor from the Cobalt part #12569241
Originally Posted by Shinobi'sZ
(Post 1565591430)
When is the next get together I am tired of just driving my car to work on occasion and giving people rides. I was thinking Vette Magic would be good, but if the weather (in June) is 100*+ out I have no desire to go to the strip and hammer on my car. Actually this weekend would have been perfect for a track day at Sacto. Arnel |
