Kumho Tire Question
Like others I'm having a heck of a time trying to find a suitable replacement tire for my 2006 C6. I have 2 questions regarding Kumho Ecsta LX Platinum tires.
If I stay away from runflats because I can;t find availability in the sizes needed would these be a suitable replacement non-runflat? Note that this tire comes in 245/40 in both 18 and 19 inch rims, anyone tried running same size tire on the front and back? Primary concerns are tread wear and highway use. |
Originally Posted by Ammo
(Post 1565536804)
ttt
I put a set of the Kumho's on my 05. They make the correct sizefor the rear now but somehow the tire shops catalogues are not up to date. Anyway, I love these. They are very quiet and smooth. They balanced nicely. I have no problems at all. They are Z rated so they must meet certain standards. I would recommend them.:thumbs:
I have Kumho Ecsta tires on my Volvo. The only issue I have had is a get a lot of bubbles in the sidewalls. There are a ton of potholes in my area and my Kumho's are low profile (P235/45ZR18's) but I have had 3 different tires develop bubbles in a year. Luckily I had Road Hazard Insurance and they were covered 100% but it was still a PITA to deal with. My former PZero tires went 12k miles with no bubbles over the same roads.
I have Kumho ecsta SPTs in the stock size and I think they are awesome and @ 670 bucks shipped from Tire Rack they were a great deal.
Originally Posted by Larry B.
(Post 1565537935)
Have them on my 06 in the OEM sizes. I recommend them as well! |
(Post 1565536804)
If I stay away from runflats because I can;t find availability in the sizes needed would these be a suitable replacement non-runflat? Note that this tire comes in 245/40 in both 18 and 19 inch rims, anyone tried running same size tire on the front and back? Primary concerns are tread wear and highway use. I had the same problem. I gave in and got the Firestone Firehawk Wide Oval Run-Flats in the rear ...and the Kuhmo Run-flats in front, all four factory size. To my amazment:thumbs: No problems with about 400 miles on them. Much better then matched Good Years. --Mike-- |
Oops...Sorry, I didn't follow my own #1 rule here...RTFQ (Read The F***ing Question)! The OP was asking about the new Kumho Platinum tires. I haven't seen where those are available in stock C6 sizes. I (along with several others here) have the Kumho ECSTA SPTs and absolutely love them. I've seen posts about a Kumho run-flat and am eagerly awaiting more info on those. Good Luck!
(Post 1565536804)
If I stay away from runflats because I can;t find availability in the sizes needed would these be a suitable replacement non-runflat? Note that this tire comes in 245/40 in both 18 and 19 inch rims, anyone tried running same size tire on the front and back? Primary concerns are tread wear and highway use. they have a VERY high tread wear rating and should last a long time (keep in mind this is probably 20 - 25k miles). You will not see 50k+ in any tire due to the limited tread to start with. And you must keep the ratio of rolling diameter the same front and back in order to keep traction control happy. you can change them as much as you want as long as the ratio is the same. Also your speedo will be off if you change the RD of the rear tire. as far as going with 245s in the back, they are rated for a maximum of a 9.5" rim, so it's too small for the vette's rear. not to mention that the SPTs in the proper size are actually cheaper. |
Thanks everyone, I appreciate the timely inputs, great forum. I want the Firestone wide oval rft's but looks like it will be SPT's or PS2's till there available.
Maybe Bridgestone will put something out soon in the C6 sizes, I've had good luck with them on the wifes Lexus over the years. Thanks again, Mike |
I'm waiting for my set of Kumhos to come in to Discount Tire right now. They matched the TireRack price, plus fixed my slow leak impressively back on April 1st for Free!
Originally Posted by C6400hp
(Post 1565536863)
At least get the correct sizes!:willy:
Originally Posted by phileaglesfan
(Post 1565550309)
I agree. Stay with the correct sizes. I know people would love to put the same size all around and throw a spare in the back. I think that would destroy the handling of the Vette though and possibly look weird with either too fat tires on the front or two thin tires on the rear.
I heard nothing but great things about Kumho tires, they will be my next set for sure.
Originally Posted by LMB 4 ME
(Post 1565552692)
Another enlightenment: seeing both front and rear tires stacked next to each other! Huge difference in size when seen right next to each other!! :eek: No question of running same on both front and rear! Great customer service at the Discount store in Texarkana as well as TireRack prices. Great job by Josh. Total cost out the door with taxes, fees, etc = $789.61 |
