Z51 Replacement shocks
I am going to be replacing my shocks with in the month. Bilstein shocks are great from what I hear. (Original replacement) What about Koni Adjustables? Other that these two, what would you guys recomend???
I want the stiff ride but dont want to spend millions. I understand the stiff ride is not always desired but on an original Z51, it is required. I feel. Thank You:) |
I have the QA1 12way adjustables...they are an incredible shock. Not cheap (about $550 for a set of 4), but you get what you pay for w/ these babies. And, unlike the Koni's, you can adjust them while they are on the car...just takes seconds. My car is lowered front & rear and these shocks add a level of confidence to the suspension like you can't imagine...HIGHLY RECOMMENDED. :yesnod:
LINK |
Awseome. The car looks great. Also, with these shocks, will they lower the car at all? Do you have a lowering kit on your car?:) I completely understand; what you get it what you pay for. Thanks for the help
Originally Posted by corvette kidd
(Post 1565439439)
No, these shocks will not lower the car any...the lowering is a separate gig altogether. I didn't really use the "kit" to lower mine....just bought 12" bolts for the rear and followed some good lowering advice to get the front the way it is. http://i49.photobucket.com/albums/f2...8013CF-1-3.jpg |
cool.... the car looks real mean.. I want to lower my car a bit but not exactly sure how to go about it. I am goign to put up a post in general discussion to lower the car. Thanks for everything:)
(Post 1565440035)
If you are going to track or drive the car at the limit i fully endorse the Koni's since our other member has mentioned how good the Qs are. The rear konis do have to be taken off in order to adjust but this isn't something you do often. The bilstein z51s are a good deal but lack the control to run higher spring rates or even control the factory ones in tight fast switch back autocross. At least that's how the set i used for awhile were. I pushed on one next to a stock c5 shock and it was a good deal softer. The bilsteins feel really similar to the tokico blues which i actually run on an integra. they don't beat you up on long drives and can be quick if you have a smooth hand at the wheel.
I understand the stiff ride is not always desired but on an original Z51, it is required. I feel. I had the Konis on an IROC-Z and hated having to remove them to adjust; the QA1s sound like the real deal, IMO. |
