Fan setting for 160 stat.
Can anyone tell me what you put your fan settings to when you got a 160 deg. stat?
fan settings
Originally Posted by c6 Houston
(Post 1565221628)
Fan settings that work w 160 Stat.
(Post 1565221628)
Now for the FAN SETTINGS , 25% on at 192 78% on at 196 99% on at all other temps to 230. These settings work well . |
Cartek fan switch 181 100%:D
Originally Posted by dennis50nj
(Post 1565224288)
Thanks guys, I hope that this will help fix my P0128 Coolant Temperature (Coolant Temperature Below Thermostat Regulating Temperature) problem. What else my I need to change?
Originally Posted by LSCHLEM
(Post 1565223122)
Hey you , Did you get that p0449 problem resolved. Would like to hear.?
I would set it to come on at 165 and off at 163
(Post 1565224319)
So thats how you got that 10.92. Fan switch
i dont know if it was the Cartek fan module switch or just Cartek in general, but it was Cartek who recomended the matched parts, and Cartek tuning. with the fan module switch, it lets me hot lap the car getting oil temps to 180 and water temps 175-181 on the starting line by not staging until the fan is on, and coolant temps are on the down sweep. it actully goes to 183-185 after a good burnout, but i stage slowly until the temps are going down under 181:D |
In HP tuners, the fan % vs ECT starts at 192.. I have that at 50 pct at 192 and gradually increase the pct up to 100pct...
temp 192 196 199 203 etc pct 50 75 75 100 100 100 |
Originally Posted by xstang
(Post 1565261847)
(Post 1565261847)
temp 192 196 199 203 etc pct 50 75 75 100 100 100 192 = 25% 196 = 50% 199 = 75% 203 = 100%, etc. It rarely gets to 195 and never gets over 203 even on the hottest day. I'm not sure if this is good or not, but it seems to work. |
Originally Posted by 8850
(Post 1565262392)
Any more than about 25% @ 192* and your fan will run continuously.
Originally Posted by 6Speeder
(Post 1565265924)
Not in my car. I have 192 set to 40% percent and (with the air conditioning off) the fans DO NOT start until 192. They do not run below that.
(Post 1565266126)
Did that clear your code 0128 . Great.
