HELP how to take c6 door panels off?
l can get most of the door off but neer the door handle it wont budge?and if you can help do yo uhave any pics
thanks |
there is threads out there to do this, check c6 faq
did you remove the bolt up by the door handle, i know on passnger side u have to pry off the little door open button and theres a bolt and on the drivers side there is one somewhere to |
Originally Posted by pentavolvo
(Post 1564821480)
did you remove the bolt up by the door handle, i know on passnger side u have to pry off the little door open button and theres a bolt and on the drivers side there is one somewhere to Check my install thread, linked in my signature below. It includes door removing instructions. |
18 Attachment(s)
Here is some info from my other thread. Just ignore the insulation part.
Removal & Insulation of Door Panels This information might be beneficial to others if they decide on upgrade speakers or insulation of the doors. The driver’s door The first thing you want to do is raise the window up. Once you pull off the panel, you can’t raise the window and you won’t have access to the inner shell of the door. Attachment 48164330 The driver’s door has a total of two bolts. They are located right below the door handle. If you look closely, you will see a small plastic cover. Remove the cover and you will see the two bolts. Uses the proper tools and remove the bolts, failure of using the proper tools may strip the bolts. Attachment 48164331 Attachment 48164332 On the bottom of the door there is a little opening to pull the panel off. Just pull away at different positions. It’s going to sound like the door is ripping apart, but that’s from the plastic holders. Once you have the panel loose, don’t yank it out. There is one main cable harness that needs to be taken off. Attachment 48164333 Attachment 48164334 Once you get to this point, you will see the exposed outer door shell. You will also see the 10” Bose woofer and a large rubber cover on the left side of the door. The rubber cover provides access to the inner shell of the door. Attachment 48164335 Attachment 48164336 Remove the Bose woofer from the door. There is a little connector that you need to disconnect when the speaker is loose. Then you want to remove the large plastic cover on the left side of the door. Once all that is done, you will have partial access to the inner shell of the door. Do not remove any bolts on the outer shell of the door; these bolts hold the window system. Attachment 48164337 Attachment 48164338 Attachment 48164339 I basically covered ¾ of the inner shell of the door with Damplifer Pro and Luxury liner. It’s a tight squeeze but it’s doable with the speaker and rubber opening. That area took me about an hour or so to do. I then did the outer shell of the door with Damplifer Pro. This area is very hard to do and the surface is not flat. The outer shell took me 2-3 hours to do. Attachment 48164340 Attachment 48164341 Attachment 48164342 This pic shows an upgraded JL speaker and mount plate. A WARNING – be careful not to insulate the edges of the door because they are exposed with the door panel on. I made this mistake on the outer shell and it took me a couple hours per door to clean up. Just insulate to the edge of the panel clips, basically leave at least one-inch strip around the door without any insulation. Attachment 48164343 The driver’s side has about 10-15 pounds of insulation. But, it is so solid and it shuts better than a Lexus, a nice thump. This will definitely improve the sound of the speakers. Putting the door panel back is a partial PITA. On the top of the door panel, there are metal hooks. You want to put those in before pushing in the clips. It will help to have the window down. Just take your time to figure it out so you don’t scratch your door. When you push in the clips, make sure they are perfectly aligned, so you don’t break any. Attachment 48164344 The Passenger Door Removal of the passenger door panel is different than the driver’s side. First you have to pop off the door open button plastic piece. You will see a bolt; just remove it with the proper tools. There is another bolt on the bottom of the handrail. Repeat the process similar to the driver’s side. Attachment 48164345 Attachment 48164346 Attachment 48164347 |
great write up
I agree! Mine is loose on upper left and I have been wondering how to get it off. Great pix!!
Thx for posting!!!
:lurk:
Originally Posted by franman69
(Post 1579875549)
:lurk:
There is also a step post at the top under my Deadening-Stereo sticky install, easy to do ... :thumbs:
Originally Posted by huillery
(Post 1564821291)
thanks |
You can make sure the screws are tight without pulling the skin.
Or pull inner skin off and put something between pieces that are rubbing. |
The real trick is getting them back on.
Some use a shoestring to pull the metal tabs back on the top of the door panel. I've never done that. Just pay really close attention to where the door panel is when it comes off, then you can re-hang it doing the reverse. It's probably a good idea to replace all the fasteners while you have the door panel off as they tend to get loose pretty easily in my experience. |
where can you buy those retainers?
Originally Posted by black.z51.c6
(Post 1584512261)
you need both the male and female. I think you need 2 packages to get both doors done. |
thanks thats awesome
thanks for posting
Originally Posted by markcz
(Post 1584251450)
That was posted as a reply to a question about a squeaky and possibly loose skin, I was suggesting that he check the screws that hold it down before pulling it apart.
(Post 1586245387)
