double din in a c4???
ok guys ( and or ) gals i want to have installed a double din stereo in my 1995 c4 and do away with the blose system in there but when i checked with crotchfeild they said it will not fit .... but they could not tell me why??? whats the deal with that???? whats too small the stereo or the hole??? i dont wanna hack up my vette for a stereo... ans someone enlighten me???? thanks
There is a specalized section devoted to cat audio but I suspect that the porblem is that while the opening is high and wide enough the problem is that it is not deep enough by a long shot:thumbs:
Not deep enough and the hole is din 1/2... not double din.
I wanted to do that but its a pain to make one fit. I have an Alpine IVA D310 flip-out touchscreen im going to run instead because the deck will fit a single din hole... |
A double din will fit but you will need to enlarge the radio bezel and cut out a plastic support that supported the Bose radio.
http://memimage.cardomain.net/member...73_18_full.jpg http://memimage.cardomain.net/member...73_15_full.jpg |
Originally Posted by Hey8You
(Post 1564750473)
http://memimage.cardomain.net/member...73_18_full.jpg http://memimage.cardomain.net/member...73_15_full.jpg I considered doing the work to make this happen but decided to go single din after thinking about the work involved to make the double din fit. It does look sweet though... hmm... might have to do that now dammit! lol |
It can be done it just takes a little customization. I had to open up the console some and then sand and repaint. I'm still finishing it up.
:cheers: http://i83.photobucket.com/albums/j3...eves1/DVD3.jpg It's tied up with a transmission rebuild at the moment. Hopefully I will have the finished pics in a few weeks. |
Originally Posted by WickedVetteLT4
(Post 1564753103)
Nice! Did you just trim the stock bezel?
Circuit City installed a Pioneer AVIC-D3 with just a very little sanding of the plastic and a little change to a mounting backet. They said it was an easy install on my '91.
Gary |
