Difficult to make any judgments yet since its been stored quite a bit. Bring the tire pressure to 30lbs, continue to drive it and monitor it closely. It may be fine. I suspect you don't have a leak problem because it'd be pretty unusual to have leaks in all four tires. :thumbs:
[QUOTE=Datawiz;1564572159]Make sure the nuts on the valve stems are tight.
:iagree: This happend to me . |
Originally Posted by Modshack
(Post 1564572995)
Check your TPMS stem torque values...I had a light leakdown in my right rear...Bought a cheap ($20) 1/4" Harbor Freight torque wrench and retorqued all of them to 60 inch pounds. Every one of them was under spec by a goodl amount. Seems to be holding just fine now..
This is definetily something to check. I had this problem last summer with ny new 07. Drove me nuts. Also check the stem caps, and make sure the little gasket is able to make a good seal. Also check to see that nothing is jammed in the stem end itself causing a minor leak. My tires have since stabilized, even during winter storage.:cheers: |
