Hand / Parking / Emergency Brake (how to adjust?)
How do you adjust a hand brake in a 90 C4? I took the caliper and rotor off and there is NO adjusting nut, I looked on the hand brake mechanism and I dont see a way to adjust it from there, I looked at the cables and these's NO adusting nut???? have searched???
Automatic adjustment built into the parking brake lever.Pull out the drivers seat squab and remove the screws from the brake cover and you will see the mechanism in there.
Originally Posted by staugur
(Post 1564155447)
thanks |
anyone...
Originally Posted by Bud90
(Post 1564156960)
anyone...
More if it needs it. I can't remember if the procedure is the same for 90. I can't even remember if my 90 had dics on all corners? I'm pretty sure it did. That's what happens when you get old. Give it a try & see what happens. As Staugur suggested a little lube in the mechanism would probably help. |
I tried pulling it up firmly a number of times, nothing changed. Yes I have disks all 4 corners.
don't know about the 90 but in my '86 I took the wheels off and rotated the disc to a certain spot (used haynes manual to find it) then there's a hole you stick a flathead screwdriver in and there's a star wheel you push either up or down depending on the side of the car you're doing
How old are the rear pads and rotors?
yeah, maybe its the rear pads... Looks like there is no adjustment.
Don't the older ones have a small pad inside the RR Rotor that is used for the E-brake?
Correct me if I am wrong, but I just did my rear Brake Pads. The cable for the E-Brake went inside the RR Rotor, I just assumed it was the style where the E-Brake was like an old Drum brake using the inside of the Hub. This would be consistent with Swift_Strikers post about turning a Star wheel with a Screw Driver. |
Well, just to let everyone know. There is NO adjustment for the parking brake. My rear claipers were bad, so I had the calipers changed and now the e-brake works great.
