What is the gear ratio of the performance Axle in a 1994 Corvette?
Hi, I know 2.59's are stock on a 1994 automatic. What would it be with the performance ratio? Thanks
Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (BlueC4 LT1)
There is a rumour that they were 3:07's ??? Don't hold me to that but it sounds right. Go in under search and look up some old topics, you'll find it there. :cheers:
On my 94 auto i have for RPO:
G44=3.07 Ratio Rear Axle G92=Preformance Ratio Rear Axle |
Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (Dualnic)
G92 is the performance rear which is 3.07
Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (Springer's 95)
My '94 6sp has RPO GM3 axle rear, 3.45 ratio!
Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (R94 LT 1)
Here are the codes,
GM1 Rear Axle, 2.59 Ratio GU2 Rear Axle, 2.73 Ratio GW4 Rear Axle, 3.31 Ratio G44 Rear Axle, 3.07 Ratio G92 Rear Axle, Performance Ratio |
So if my RPO list shows GU2 (2.73) and G92 (Performance Rear) - what do I actually have. Is it 2.73 or 3.07 ???
Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (Ruby_Roadster)
How can I find out what option I had, is it in the VIN somewhere b/c I don't have any of my books or records or anything like that. Or is it stamped on the rear end or something?
So if my RPO list shows GU2 (2.73) and G92 (Performance Rear) - what do I actually have. Is it 2.73 or 3.07 ??? |
Now this has got my slightly confused... I have the G44 with G92... 3.07 performance rear... but if the G44 is 3.07.. what does the performance rear end give you? :confused:
Springer,
Try to get ahold of Scorp on this, he can usually be found in the NE section. I bet he know's the answer on this gear ratio situation. |
Now this has got my slightly confused... I have the G44 with G92... 3.07 performance rear... but if the G44 is 3.07.. what does the performance rear end give you? :confused: |
So if my RPO list shows GU2 (2.73) and G92 (Performance Rear) - what do I actually have. Is it 2.73 or 3.07 ??? This case here is why you can't say that someone has 3.07 because the have G92, (Most of the time it is true but there are some exceptions) |
Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (dgoodhue)
So is it possible to have G44 (3.07) without the G92?
So is it possible to have G44 (3.07) without the G92? |
My '94 6sp has RPO GM3 axle rear, 3.45 ratio! A '94 with the "performance ratio axle" should be 3.07's. Oh, and all '94's with auto's had a Dana 36. Manuals had a Dana 44 with 3.45 [Modified by Glock'94, 6:29 PM 12/13/2001] [Modified by Glock'94, 6:31 PM 12/13/2001] |
