How do you change the DIC Welcome Message?
I was reading on the C6 General Discussion forum about all the cool DIC Welcome Messages people programmed when they start their cars - can we do this on the C5 too? If so, what's the procedure? I used SEARCH but couldn't find anything :cool:
Originally Posted by AlohaC5
(Post 1563996743)
:cheers: |
Originally Posted by Y2Kvert4me
(Post 1563996830)
Nope. :nonod:
:cheers: :cheers: |
someone said you'd have to crack the ecu's code in order to do that. even if someone knew the code I'm sure GM would frown apon anyone reprogramming it.
I finally found a good reason to tell my wife why I need to purchase a new Z06!! Sounds reasonable to me :thumbs: Wish me luck..:D
Originally Posted by noahdr
(Post 1563997697)
ask evil twin, he probably knows
(Post 1563996830)
Nope. :nonod:
:cheers: with the right tools I have seen it |
Originally Posted by IBUID40
(Post 1564000775)
Yes you can do it
with the right tools I have seen it :skep: :skep: First I've EVER heard that it can be done on a C5. You sure it wasn't a C6 and you were just a bit tipsy??? Didn't know any better?? :D |
(Post 1564000775)
Yes you can do it
with the right tools I have seen it You may have seen a "Photoshop" picture where someone has super-imposed a new "message" in the picture ..... The C5 message is stored in the IPC; without an EEPROM burner, and a whole lot of information on where the message is located in memory, you can't change the message. If you've seen it, ask the person who modified the message for the starting hex address that they found in the IPC memory for the message :cheers: |
What's Photoshop?
Originally Posted by dndrsn
(Post 1564002054)
What's Photoshop?
EDIT: Are you asking seriously? Because your avatar looks photoshoped. |
Originally Posted by 01silvercoupe
(Post 1564002196)
Image editing software
EDIT: Are you asking seriously? Because your avatar looks photoshoped. No just joking, and yes it is photoshopped. Go Tigers ! David |
(Post 1563997798)
Apparently its easy for the C6 guys to do without any special tools - its an option in the DIC.
(Post 1564002414)
Hello neighbor,
Originally Posted by VRROOOM2
(Post 1564000999)
You sure it wasn't a C6 and you were just a bit tipsy??? Didn't know any better?? :D Not sure if it was a video edit or a tech2 mod or what |
If its a trade off between the C5 DIC, which provides us OBD-II codes, vs. the C6 DIC that doesn't but lets you change the "Welcome Message".... I'll take the C5 DIC. Thanks.
If you can tune the eprom you can change ANYTHING
Burning a new code in an eprom isn't a major activity. Just need someone who knows the procedure. I burned new eproms on my PCAT over 10 years ago. If anone KNOWLEDGABLE here knows HOW to do it then thats that. Not rocket science.:eek: :smash: :withstupid: BIGHANK
Originally Posted by bighank
(Post 1564007113)
Originally Posted by abraswell
(Post 1564007444)
Awesome! Let us know when you get the procedure all figured out. :D
