Originally Posted by GrandpaC6
(Post 1605582029)
I don't have it right now.
For some reason, the max rpm that I could rev to or footbraking is ~ 2500 (500whp). Yank response: "That is about right because the converter we sent you is a 4,000 flash stall so footbrake is always about 800-1000 RPM less. Also, the triple disk converters are a little harder to stall under lower horsepower. "" |
(Post 1605582029)
Originally Posted by Omega Doom
(Post 1605584751)
i wonder if this could be your issue?
Came across many success stories on 4000rpm Yank TC, hence I ordered it. Maybe 3200 or 3600 could have been better? |
(Post 1605584802)
Not really sure. What TC would you recommend for 530whp A6 vette?
Came across many success stories on 4000rpm Yank TC, hence I ordered it. Maybe 3200 or 3600 could have been better? I haven't hurt a circle d converter yet and I dropped over 3/10 off the 60ft and picked up mph out back even unlocked circle d vs unlocked yank. |
Originally Posted by asd_srt
(Post 1605585418)
Circle d or fti all the way. I had 2 yanks and they were trash both broke within a few months. One ended up hurting a transmission. I talked to yank about the issues I had with their PAS3400 converter and they blamed everything but the converter. So I bought a circle d and my issues went away with no other changes.
(Post 1605584802)
LS2 sbe, A6
Yank triple disk 4000rpm stall, Ported ls3 heads, ARH 1-7/8, 102 TB, tsp stage 2 cam. Lod x1 intake 26x8.5x17 hoosier DA +1500 Weight almost 3400 11.2 @ 125 I think 8 inches wide tires isn’t helping in 60. Trying 315x35x17 next. https://cimg0.ibsrv.net/gimg/www.cor...7449ae75a.jpeg |
Category: Showroom Stock LS2
1. Your entire profile completed & read Instructions: 2. A copy of your entire time slip posted to the thread as in post # _____ 3. The complete the details of your pass using this template in your post: 4. Year Corvette 2006 5. Type of Trans A6 6. Type of Suspension stock 7. Stock Performance options none 8. Tires utilized General, hard street tires 9. Modifications if any Diablosport 93 0ctane tune 10. Dyno numbers if you have them NA 11. 34 PSI, sport mode , traction control off , 2.56 gears 12. Canned tune that came loaded it the Diablosport tuner. ___ Name of the Track Beech Bend ___ Date of the pass & weather conditions 5-9-23 6 PM 73° F ___ 60'.............1.93 ___ 330'...........5.36 ___ 660'...........8.1= ___ 660’ mph....90.54 ___ 1000'.........10.45 ___ 1320'.........12.42 ___ 1320’ mph…114.80 https://cimg4.ibsrv.net/gimg/www.cor...727e4da146.jpg |
Category: External Modifications Bolt Ons
Time Slip: Attached Year: 2008 Trans: A6 Suspension: Z51 Gears: Stock 2.73 Tires: Nankang Sportnex AS-2+ Modifications: Corsa Sport mufflers, trans software tuned Dyno numbers: N/A About 1/3 - 1/4 tank of gas, ca. 32 psi rears and 36 psi fronts Name of the track: Pudasjärvi Airfield Date / Conditions: 17.06.2023 / Sunny weather, temp 70-75 F, elevation 397 ft from sea level 60'............... 2.110 s 330'............. 5.419 s 660'............. 8.148 s 660 mph...... 90.85 mph 1000'........... 10.488 s 1320'........... 12.450 s 1320' mph... 114.77 mph https://cimg6.ibsrv.net/gimg/www.cor...2498ea5ea1.jpg |
Is the thread still active? Just took a closer look and the last time the list has been edited was seven years ago...
Been dead for a long time.
Originally Posted by m60gov20
(Post 1607174967)
Originally Posted by Yorcci
(Post 1607175172)
...because nobody keeps the list anymore or that nobody cares?
Originally Posted by HOXXOH
(Post 1607177470)
Because the list creator turned it over to his friend to maintain and later on the friend just walked away. Lots of people would like it to continue, but the forum rules that exist don't seem to have that option. It started in 2005 and 11 years later had 7242 posts when it "stalled". Here we are 7 more years and added slightly over 200 more posts, but roughly 300,000 views.
https://cimg0.ibsrv.net/gimg/www.cor...30cf00b8ab.jpg
Built motor with Eforce Supercharger and 4l60 trans. It'd be cool to have an updated list. I bet there a lot faster cars out there then currently on the list. |
8.47s @ 164, with 1.32s in 60’
2005 C6 3350 Lbs with me in Twin turbo 18 psi making almost the 1027whp. DA was 1800+ https://cimg2.ibsrv.net/gimg/www.cor...5f577a725.jpeg |
Category: Internal Engine Modifications LS3
1. Your entire profile completed & read Instructions: 2. A copy of your entire time slip posted to the thread as in post # _____ 3. The complete the details of your pass using this template in your post: 4. Year Corvette: 2008 5. Type of Trans: A6 6. Type of Suspension: stock 7. Stock Performance options: none 8. Tires utilized: 275/40r17 Hoosier Dr2 9. Modifications if any: Ls3 base 416 short block, BTR custom cam, Stock (unported, unmilled) Ls3 heads with BTR .660 springs and ti retainers, Circle D torque converter, BTR Trinity intake manifold, kooks 2" headers, Vararam intake, flex fuel, FIC (clinic) 60lb injectors, twin Walbro fuel pumps, TBM rear brakes, BST differential brace, Race weight 3400lbs, tuned by myself. 10. Dyno numbers if you have them: NA 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: 22psi tire pressure, 2400rpm foot brake launch 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track Beech Bend ___ Date of the pass & weather conditions 7Feb24 3 PM, 55° F, -320 DA ___ 60'............. 1.41 ___ 330'........... 4.09 ___ 660'........... 6.33 ___ 660’ mph.... 107.7 ___ 1000'......... ___ 1320'......... 9.90 ___ 1320’ mph…137.32 https://cimg1.ibsrv.net/gimg/www.cor...f692200207.jpg |
(Post 1607742957)
1. Your entire profile completed & read Instructions: 2. A copy of your entire time slip posted to the thread as in post # _____ 3. The complete the details of your pass using this template in your post: 4. Year Corvette: 2008 5. Type of Trans: A6 6. Type of Suspension: stock 7. Stock Performance options: none 8. Tires utilized: 275/40r17 Hoosier Dr2 9. Modifications if any: Ls3 base 416 short block, BTR custom cam, Stock (unported, unmilled) Ls3 heads with BTR .660 springs and ti retainers, Circle D torque converter, BTR Trinity intake manifold, kooks 2" headers, Vararam intake, flex fuel, FIC (clinic) 60lb injectors, twin Walbro fuel pumps, TBM rear brakes, BST differential brace, Race weight 3400lbs, tuned by myself. 10. Dyno numbers if you have them: NA 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: 22psi tire pressure, 2400rpm foot brake launch 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track Beech Bend ___ Date of the pass & weather conditions 7Feb24 3 PM, 55° F, -320 DA ___ 60'............. 1.41 ___ 330'........... 4.09 ___ 660'........... 6.33 ___ 660’ mph.... 107.7 ___ 1000'......... ___ 1320'......... 9.90 ___ 1320’ mph…137.32 https://cimg1.ibsrv.net/gimg/www.cor...f692200207.jpg Your ET is my next goal. Is there a way to stroke a 6.0. Need something similar to your setup. Currently stock sbe, ls3 ported heads, circle d 4000 stall and intakes. DA here will never go below +500. |
(Post 1607742992)
Superb man! Congrats.
(Post 1607742875)
