MPSS OEM Runflat tires 60' on the C7/Z06
I went from a 2010 GS to a 2015 Z06 A8 with the factory MPSS runflats that has put down I believe a better 60' than the runflat Cup tires that are also available as OEM on the C7/Z06.
Pic of two different runflat time slips below: http://i1037.photobucket.com/albums/...psd0yusl5a.jpg |
Originally Posted by C7/Z06 Man
(Post 1593379379)
Pic of two different runflat time slips below: http://i1037.photobucket.com/albums/...psd0yusl5a.jpg lol whatever 1.5 on runflats lol |
1 Attachment(s)
ls3 , poweradder list
4. Year Corvette 2008 5. Type of Trans 6l80e 6. Type of Suspension base bone stock 7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.56 gear non z51 8. Tires utilized 28x11.5x16 9. Modifications if any kentucky speed spec cam, honker cai, 1 3/4 headers, 3200 fti billet converter ,nitrous outlet direct port 225 shot, rod mod inside the intake, x pipe to y pipe to turn down for exhaust, bluecat tuned 10. Dyno numbers if you have them 652/707 on a 175 shot no dyno on the 225 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc stalled up to 2000 , 16 lbs in the tires, 2000 -7000 on the window switch and 100% on the progressive at wot 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track mountain park dragway , clay city kentucky ___ Date of the pass & weather conditions 11/5/16 about 1200 da ___ 60'............. 1.370 ___ 330'........... 3.952 ___ 660'........... 6.090 ___ 660’ mph.... 115.212 ___ 1000'......... ___ 1320'......... 9.480 ___ 1320’ mph… 144.523 |
made it to the 11 second club
Category:LS3 bolt on
4. Year Corvette 2008 5. Type of Trans A6 6. Type of Suspension Base 7. LT's-OBX, catback with cats, drop in air filter, ported throttle body 8. Tires utilized: stock 9. Modifications: diablew mail tune 10. Dyno numbers-None 11. As much info you may want to add about the run, launch-1500 rpm then floored it at the light 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track-Mason Dixon Dragway ___ Date of the pass & weather conditions 11/6/16, sunny 65 degrees ___ 60'.............1.959 ___ 330'...........5.218 ___ 660'...........7.831 ___ 660’ mph....94.63 ___ 1000'.......... 10.060 ___ 1320'..........11.924 ___ 1320’ mph….121.38 https://cimg3.ibsrv.net/gimg/www.cor...492d07d4aa.jpg |
anyone updating the list lately?
Originally Posted by MidYearRoadster
(Post 1593460017)
Category: - GrandSport Stock
1. Your entire profile completed & read Instructions: - yes 2. A copy of your entire time slip posted to the thread as in post # _____ below 3. The complete the details of your pass using this template in your post: 4. Year Corvette - 2012 5. Type of Trans - 6at 6. Type of Suspension - stock 7. Stock Performance options (as in optional gears with the automatic, & etc.) - mag ride 8. Tires utilized - stock 9. Modifications if any - no 10. Dyno numbers if you have them - 372hp 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc - front tires at 30psi, rear tires at 25psi, launched at 1200rpms with TS off and trans in sport mode 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track - Englishtown Raceway Park ___ Date of the pass & weather conditions - 11/13/2016 ___ 60'............. 1.966 ___ 330'........... 5.338 ___ 660'........... 8.073 ___ 660’ mph.... 88.11 ___ 1000'......... 10.415 ___ 1320'......... 12.374 ___ 1320’ mph… 115.61 Copy of Time Slip Below https://cimg9.ibsrv.net/gimg/www.cor...e797cae78e.jpg https://cimg7.ibsrv.net/gimg/www.cor...b7ffb22c2f.jpg |
New Best
1 Attachment(s)
Category: LS3 Showroom Stock
1. Your entire profile completed & read Instructions: 2. A copy of your entire time slip posted to the thread as in post # _____ 3. The complete the details of your pass using this template in your post: 4. Year Corvette 2008 5. Type of Trans A6 6. Type of Suspension Stock 7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.73 rear axle 8. Tires utilized Firestone Firehawk Indy 500s 9. Modifications if any NA 10. Dyno numbers if you have them NA 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc Ran in Sport mode, no adjustments to tire pressure, blew tires off in other lane that is normally quicker 12. Typed in the post (as some time slips get deleted & etc after being posted) Fayetteville, NC Motorsports Park 11-20-16, 3:53 PM, approximately 53F, humidity 26%. ___ 60' 1.9375 ___ 330' 5.2152 ___ 660' 7.8772 ___ 660’ mph 92.54 ___ 1000' None ___ 1320' 12.0722 ___ 1320’ mph 117.59 |
Originally Posted by Derek S Dickens
(Post 1593509241)
1. Your entire profile completed & read Instructions: 2. A copy of your entire time slip posted to the thread as in post # _____ 3. The complete the details of your pass using this template in your post: 4. Year Corvette 2008 5. Type of Trans A6 6. Type of Suspension Stock 7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.73 rear axle 8. Tires utilized Firestone Firehawk Indy 500s 9. Modifications if any NA 10. Dyno numbers if you have them NA 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc Ran in Sport mode, no adjustments to tire pressure, blew tires off in other lane that is normally quicker 12. Typed in the post (as some time slips get deleted & etc after being posted) Fayetteville, NC Motorsports Park 11-20-16, 3:53 PM, approximately 53F, humidity 26%. ___ 60' 1.9375 ___ 330' 5.2152 ___ 660' 7.8772 ___ 660’ mph 92.54 ___ 1000' None ___ 1320' 12.0722 ___ 1320’ mph 117.59 Most impressive sir. It always blows my mind seeing the #'s produced of the top 4 in the LS3 stock category. |
Originally Posted by Z51LS3
(Post 1593510595)
It always blows my mind seeing the #'s produced of the top 4 in the LS3 stock category. Not sure if I'll chase the elusive perfect 11.99 run stock or make some minor mods over the winter. |
2 Attachment(s)
Category: Internal engine modification GS
1. Your entire profile completed & read Instructions: Yes 2. A copy of your entire time slip posted to the thread as in post # _____ posted below 3. The complete the details of your pass using this template in your post: 4. Year Corvette 2012 5. Type of Trans M6 6. Type of Suspension stock 7. Stock Performance options NPP 8. Tires utilized MT DR 315/35/17 9. Modifications: CAI, Head/Cam, Headers, Fast 102, drag pack, stock NPP, 4.10 gears 10. Dyno numbers if you have them Not yet 11. 3470 race weight, 600 DA, stock clutch, 5500 rpm launch. 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track MIR ___ Date of the pass & weather conditions 11/18/2016 70 and sunny ___ 60'.............1.385 ___ 330'...........4.313 ___ 660'...........6.719 ___ 660’ mph....102.14 ___ 1000'.......... 8.775 ___ 1320'..........10.491 ___ 1320’ mph….131.83 |
New PB
5 Attachment(s)
Category:LS3 Power Adder
1. Your entire profile completed & read Instructions: 2. A copy of your entire time slip posted to the thread as in post # __Added below___ 3. The complete the details of your pass using this template in your post: 4. Year Corvette /2009 5. Type of Trans /Bone Stock original 6L80/2800 Single Disc Vigilante Converter 6. Type of Suspension/Factory Stock lowered on stock bolts 7. Stock Performance options (as in optional gears with the automatic, & etc.) /None 8. Tires utilized /M/T 305/45/18 9. Modifications if any /S/C,meth,hdr,tune/D/R 10. Dyno numbers if you have them /Hadn't been on dyno in 3 years 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc /Tires at 15lbs,launched at 2000 RPM,Shiftpoints at 5300,6300,6300 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track/Royal Purple Raceway/Baytown,Texas ___ Date of the pass & weather conditions/11/20/2016/clear and cool ___ 60'/ 1.537 ___ 330'/ 4.201 ___ 660'/ 6.440 ___ 660’ mph/ 110.44 ___ 1000'/ 8.364 ___ 1320'/ 9.988 ___ 1320’ mph/ 138.56 Copy of Time Slip Below Attachment 48128583 Attachment 48128584 Attachment 48128585 Attachment 48128586 Attachment 48128587 |
Congrats on the pb that's flying! You running an A&A V3Si correct?
Originally Posted by JetstreamGS
(Post 1593520358)
(Post 1593509241)
https://cimg6.ibsrv.net/gimg/www.cor...e2f81650ce.jpg
Category:LS3 bolt on 4. Year Corvette 2008 5. Type of Z51 M6 6. Type of Suspension Z51 7. BNB Bullets Exhaust, Halltech super bee intake, tune 8. Tires utilized: KDW's 255/295 9. Modifications: mayhem motor sports dyno tune 10. Dyno numbers-414whp/412wtq 11. As much info you may want to add about the run, launched 2k rpm and quickly squeezed down to full throttle 12. Typed in the post (as some time slips get deleted & etc after being posted) ___ Name of the Track Rockingham Dragway ___ Date of the pass & weather conditions 11/19/16, partly cloudy, 65 degrees ___ 60'.............2.022 ___ 330'...........5.342 ___ 660'...........8.019 ___ 660’ mph....94.65 ___ 1000'.......... ??? ___ 1320'..........12.219 ___ 1320’ mph….117.20 |
(Post 1593548386)
what size firestones ...how are they hooking up?
Originally Posted by danielwebb
(Post 1593554310)
(Post 1593509241)
(Post 1593568104)
Stock sizes 245-40-18s on front and 285-35-19 on back. I like the tires. They hook much better than the Goodyear F1 Run Flats did. They also ride smooth and I like the look too.
Classes: 1.) Showroom stock The way it came from the factory, stock tires, air path, stat & etc. You may add or decrease tire pressure, have as much or as little gasoline as you like The list and rules are only meant to show what the capabilities are under each category as a comparison of mods. Since weather conditions vary immensely and affect the results, timeslip data can be factored in to get a better feel for local conditions than just the raw numbers. I don't make or enforce the rules, but even though your submission didn't follow them for the Showroom stock class, it can still be helpful to others. Just re-submit using your best timeslip when using the OEM GY's and additionally include the timeslip with the Firestones to show how much difference a tire can make. Learning and helping is what this forum is all about. :thumbs: |
1 Attachment(s)
Got a new best at Atco today, Still need some time to work on getting a good 60ft with this new setup but the car is moving. A 15" slick next year should make things real interesting.
Category : Power Adders LS2 1. Your entire profile completed & read Instructions: Yes 2. A copy of your entire time slip posted to the thread as in post # _7281_ 3. The complete details of your pass using this template in your post: 4. Year Corvette : 2007 5. Type of Trans : M6 6. Type of Suspension : Z51 7. Stock Performance options (as in optional gears with the automatic, & etc.) : Z51 8. Tires utilized : 275/40/17 Hoosier DR's on C5 ZO6 speedlines/ GTO spares with M&H Racemaster Bias-Ply 9. Modifications if any : Procharger F1-R, RPM Blower Cam, Meth injection, AR Headers w/Cats, Corsa Extreme CB, MGW shifter, Ported FAST 102, Ported stock TB, RPM stage 6 TR6060, RPM stage 4 rear, Mantic 9000 Clutch, 160 t-stat, Deka Battery, Stock bottom end/stock heads, Built and tuned by RPM Motorsports 10. Dyno numbers if you have them : 849hp/733tq 11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : 16psi rear tires/ 40psi fronts, passenger seat and front sway bar removed, 1/3 tank of gas, 250lb driver ___ Name of the Track - Atco ___ Date of the pass & weather conditions - 12/2/16 - 50 degrees -500DA ___ 60'.............1.670 ___ 330'...........4.443 ___ 660'...........6.643 ___ 660’ mph....111.59 ___ 1000'.........8.504 ___ 1320'.........10.030 ___ 1320’ mph….149.93 Copy of Time Slip Below: Attachment 48128447 |
