NAPA Synthetic Oil
Has anyone used the Napa full synthetic oil? Any reason to stay away from it? It is one sale this month. http://www.napaonline.com/Flyer0710/Main.asp
I am planning an oil change and thought I might use it this time. |
It does not say what specs it meets. If it does not say on the label that it meets the GM 4718M spec, stay away.
You should look to see if it meets GM spec "GM 4718M"
P.S. Tom73 beat me to the answer. Great minds think alike! |
Mobil1 is sale priced at Wal-Mart. Why would you want to experiment with oil?
Originally Posted by WetteVette
(Post 1562342801)
As long as the NAPA oil meets the GM specs I think it would be fine. I am sure some other company manufactures it for them. You may want to try and find out who makes it for them. But, I prefer to spend the extra and run Amsoil or Royal Purple. Just my $.02... |
Originally Posted by crazyv6
(Post 1562342859)
I would pay $20/quart for Modil one before I would ever shop at walmart!:nono:
Originally Posted by 2004SpiralGrey
(Post 1562343006)
I don't understand why. They have great prices there. It's usually $20 for a 5 quart jug of Mobil 1.
Does anyone know the spec. on the NAPA oil?
I can not find it on there web site. |
According to one of their counter guys it is made by Ashland Oil. Ashland oil also makes Valvoline.
(Post 1562342859)
(Post 1562343539)
Originally Posted by LoneStarFRC
(Post 1562344521)
The oil is manufactured by Valvoline per MSDS info.
(Post 1562342859)
Originally Posted by Tom73
(Post 1562344469)
Another one of those WalMart haters :willy:
If you read your owner's manual, you'll see that GM does allow alternatives to the 4718M spec. There is a good article here:
http://www.idavette.net/hib/C5diy/c5diy1.htm Scroll down to "What kind of oil?" Here is an exerpt. The second oil selection issue to address is the Service Manual statement that LS1s operated in North America use only an oil meeting GM Standard 4718M. The Manual also states that oils meeting 4718M might be hard to find outside North America and that LS1s operated in such places can use any 5W-30, 10W-30 or 10W-40 petroleum or synthetic oil meeting APIĘSJ and Association des Constructuers Europeens de l'Automobile (AECA) Standard 3-96. I use Castrol 0w-30 full synth, German made. Excellent oil analysis results. |
Originally Posted by z06Bigbird
(Post 1562353402)
How come you never have more than .02 cents????
Originally Posted by kdub1
(Post 1562353499)
http://www.idavette.net/hib/C5diy/c5diy1.htm Scroll down to "What kind of oil?" Here is an exerpt. The second oil selection issue to address is the Service Manual statement that LS1s operated in North America use only an oil meeting GM Standard 4718M. The Manual also states that oils meeting 4718M might be hard to find outside North America and that LS1s operated in such places can use any 5W-30, 10W-30 or 10W-40 petroleum or synthetic oil meeting APIĘSJ and Association des Constructuers Europeens de l'Automobile (AECA) Standard 3-96. I use Castrol 0w-30 full synth, German made. Excellent oil analysis results. Look for two things: • GM4718M Your vehicle’s engine requires a special oil meeting GM Standard GM4718M. Oils meeting this standard may be identified as synthetic. However, not all synthetic oils will meet this GM standard. You should look for and use only an oil that meets GM Standard GM4718M. Notice: If you use oils that do not have the GM4718M Standard designation, you can cause engine damage not covered by your warranty. • SAE 5W-30 As shown in the viscosity chart, SAE 5W-30 is best for your vehicle. However, you can use SAE 10W-30 if it is going to be 0°F (-18°C) or above. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils such as SAE 20W-50. Oils meeting these requirements should also have the starburst symbol on the container. This symbol indicates that the oil has been certified by the American Petroleum Institute (API). You should look for this on the oil container, and use only those oils that are identified as meeting GM Standard GM4718M and have the starburst symbol on the front of the oil container. Your vehicle’s engine is filled at the factory with a Mobil 1® synthetic oil, which meets all requirements for your vehicle. Substitute Engine Oil: When adding oil to maintain engine oil level, oil meeting GM Standard GM4718M may not be available. You can add substitute oil designated SAE 5W-30 with the starburst symbol at all temperatures. If temperatures are above 0°F (-18°C), you may substitute SAE 10W-30 with the starburst symbol. Substitute oil not meeting GM Standard GM4718M should not be used for an oil change. |
Maybe it's just me but.........
Why buy a performance car and worry about a few bucks more in the cost of oil?
Just use the Mobil 1.. |
(Post 1562353630)
Because I don't have a job!
Originally Posted by Groucho
(Post 1562356808)
