Wow, I feel like i just slept at a Holiday Inn last night.
That was very well written Brian, thanks for sharing. :thumbs: |
Is Brian still selling these PWM's?
So, is Brian selling these things anymore? I've still got a MkVIII fan and serpentine setup to install and I, like DB, would like to have a variable speed control that works. If I get one, I think I'll wire it from the battery too.
Wow I just found this tread, I've been really busy and havn't had much Forum time :ack:
I love this kind of stuff. Automotive electrical is pretty easy compared to some things out there. Slow, Low and sloppy. I must say that Baskin1 really sounds pretty pompus. He has a known failure mode on a hot seller and his fix is to tell customers not to do that. He tries to explain the issue by saying that the problem is a voltage current phase error in the charging circuit. Then he sends us to a link on oscilliators???:rolleyes: Hmm, OK, except that we are talking DC, which has a pretty dang long period ( like the life of the battery ) I don't care how the Alt creates the power, only what comes out of it. and that a 3 phase fully rectified DC signal. Like this; http://www.ibiblio.org/obp/electricC...Semi/03269.png Now Baskin could try and make the argument that it's pulsed DC since the alt is rectified. But then he says the battery filters it, and the 10ga wire acts as an inductor(of non trivial value I assume? Sure...) So how can anyone make the argument that there is any phase error in a DC circuit with a large battery and a large gauge wire connection to the Charging system? The boy is grasping at straws. I would have believed him if he said there are 1.5kv swithching spikes at the altenator that get attenuated closer to the battery to a tolerable level. Or even that he doesn't really know why it happens but it does fail frequently when connected to the alt and rearely when connected to the Battery. ( Which is what I suspect it the truth, he doesn't really know) But Phase errors in a DC curcuit??? Give me a break! Keith |
Wow I just found this tread... with YOUR version of Brian bashing horse pucky. NICE. |
Originally Posted by 427V8
(Post 1562497456)
Well this is fun thread:cool: To the poster that mentioned high freq as the reason speakers blow. The leading cause of voice coil failure is signal clipping....simply put: voice coils (and the amp that drives it) are designed to deliver (amp) and accept (voice coil) an AC waveform only. Clipping imposes DC on the coil, resulting in excessive heat being generated, and the resulting death of the voice coil.....sometimes with a nice small fire:eek: Leading reason this happens: underpowered amps being overdriven. Buy a big power amp, stick with 18db xovers and never look back!!!
Originally Posted by baskin1
(Post 1562466270)
I have an idea, why don’t the two of you get little cowboy and indian outfits and pretend to be that instead of engineers, at least giving advice on how to make corn meal won’t damage anyone’s car.
Originally Posted by sjmaster
(Post 1562501201)
(Post 1562501201)
Buy a big power amp, stick with 18db xovers |
It does not stop clipping, but does limit the energy delivered to the speaker due to the sharp cutoff freq. Applying the freq range a speaker was designed to reproduce, and not feeding it "notes" above and below it's range, results in less or maybe even no overloading of the driver. I should not have mentioned "non clipping" related items in the same paragraph...beat this engineer:o :smash:
In all seriousness, this is a great thread. Learning how your equipment works make you a better operator!!! |
OK thats what I thought.
HEHE....guys lets not confuse Brain Baskin with 3 color diagrams....
second off, any body wanna bet I can design a better controller??? but not VARIABLE speed,,.....lets just go for simplicity and CHEEPness.. how about something that does what 'they' claim for an aftermarket price of less than 100 bux or a junkyard price of 'FREE'>>> Good old electronics, allways more and more for less and less..... kinda makes me want to advizzzze my kids into that field.....NOT!!!!.... |
LOL, Gene, what are you going to invent for us? The Switch?:thumbs:
Originally Posted by SIXFOOTER
(Post 1562517806)
Naaa.....a solid state Rheostat..... complete with pulse inverter and inverse logic, that inverse logique was a French invention.... :lol: |
Originally Posted by mrvette
(Post 1562517284)
but not VARIABLE speed,,.....lets just go for simplicity and CHEEPness.. |
Originally Posted by I'm Batman
(Post 1562520998)
I could whip up a twin-relay on/off controller in about five minutes. That's not the point. The point is preventing the fan from hitting the electrical system with a 105A startup spike. That can't be terribly good for everything else.
All fine and dandy, I run a 17SI 108 amp alt with serp drive....it's larger diameter than the other SI series alts....came on a '79 Seville with r/wind defogger.....at any rate, it's a bolt in swap, and off that alt I wired a fuse link about 2" long and ~10 ga wire to the fan relay, which is hard on and hard off, was there that way for some 5 years running an '87 vette fan in stock '72 shroud....got rid of that when going to the dual spals running essentially the exact same wiring setup/relay...hard on/hard off, works fine....see a slight pull on the voltmeter when the fans come on for maybe 1/2 second or so...that's all.... NOW, I could put in another relay with a lower temp setting than the computer has, with a series resistor and let them fire up slower, but WHAT is the POINT???? Noise?? you exhaust is too quiet....I barely hear my fans....true my hearing is shot from too much loud stereo over the decades, that and the gun hobby too...:lol: :lol: :eek: :yesnod: Actually they not significantly louder than many other cars/trucks..... |
This controller has a soft start feature also:
http://store.summitracing.com/partde...5&autoview=sku |
Originally Posted by shafrs3
(Post 1562524283)
http://store.summitracing.com/partde...5&autoview=sku :lol: |
Well, I got a little less lazy now, and dug out my old scope.....
on the a/c input, I see the 3 fuzzes all nice and neat, and so put trace on super slo.....at the power out stud, it dips damn close to 6 volts, down to 8.8 volts or so....maybe a schosch less on instant fans turn on.....whoopie doo, lasts about 200 ms...... in other words, NOT AN ISSUE..... |
mrvette
you beat me to it. i was going to get my tek scope out (if i could find it). did you try to get a pulse on start-up? maybe sync it to the sense wire to hold the image on the first revolution of the alternator. i think that's were these voltage spikes are supposed to occur. if someone has a newer scope with a memory, the first few seconds could be captured. jeff |
Originally Posted by jnb5101
(Post 1562525295)
mrvette
you beat me to it. i was going to get my tek scope out (if i could find it). did you try to get a pulse on start-up? maybe sync it to the sense wire to hold the image on the first revolution of the alternator. i think that's were these voltage spikes are supposed to occur. if someone has a newer scope with a memory, the first few seconds could be captured. jeff wasn't particularly after images, just amplitudes.... 200 ms/box sweep,,....so saw the dip and recovery.... of course withthe fans on the output was a bit more raggedy looking cause I was about 2 volts per box, seeing some ignition noise, and some slight trash when the fans were on, but with them off, the output was very smooth....but at any rate it seems less than a volt worth of trash under worst condiitons....maybe 1/2 a volt due to the 3 phase outputs....like I said...whoopie doo.....not an issue.... |
