Rear View Mirror with map light
I saw one of thses on Ebay for an 84 . The seller said there is a plug behind the upper molding. I have not lokked yet, but is there a plug for that thpe of mirror?
Thanks, Hugh :flag: |
:yesnod:
A Big Yes, It's A Quick Discount!
So your saying the guy waas full of it? :nono:
There wasn't one on my '85 but it isn't hard to hook up, just run wires down the pass. side A pillar and make all needed connections under the dash behind the radio.
i bought one of these on ebay. Best upgrade i ever did. it adds much need light at night. Take the upper molding off and the wire/plug should be right there.
Wiring was there on my '86. Nice upgrade.
I am not mechanicaly or electricaly inclined so I would have on heck of a time installing it.
Hugh :willy: |
If I am not mistaken, and please correct me if I am wrong, but the lighted rear view mirror didn't show up on the Vette until the appearance of the convertible in 86. If that is the case, 84's and 85's won't have the plug under the moulding (maybe early 86's as well). If that is indeed the case, you'll have to separately run the wires to give the mirror lights power.
I needed a new rear view mirror for 85 and found a lighted one way cheaper than the non-lit stocker, so I bought it. Its installed, but I haven't hooked up the lights yet. I had planned to tap into the wiring for the lights on the visor to get power to the lights. |
Originally Posted by ejscarfo
(Post 1562258899)
I needed a new rear view mirror for 85 and found a lighted one way cheaper than the non-lit stocker, so I bought it. Its installed, but I haven't hooked up the lights yet. I had planned to tap into the wiring for the lights on the visor to get power to the lights. I don't know I will ask my Mechanic, your probably correct. Hugh |
(Post 1562258899)
I needed a new rear view mirror for 85 and found a lighted one way cheaper than the non-lit stocker, so I bought it. Its installed, but I haven't hooked up the lights yet. I had planned to tap into the wiring for the lights on the visor to get power to the lights. if installing a lighted mirror in a '84 or '85 you could just tap into the wires that lead to the vanity mirror on the sun visor. |
My 87 has it, I didn't find out until last night!
