The C6 Z06 Fast List
The C6 Z06 Fast List is hereby established at the request of members and has been made easy to locate amid the stickies atop the C6 Z06 board.
The purpose of the list is to consolidate documentation addressing the question, “What kind of quarter-mile times do the C6 Z06s run?”. As owners quickly discover, C6 Z06s are very fast cars that require driver skill and experience to coax out all of the performance potential built-in by the Corvette engineering and production teams. ======================================== == The official GM acceleration specification for the quarter mile is: 2006-2012 (505 horsepower)…11.7 125 ======================================== == That spec represents the average of a large number of passes driven by Chevy's professional drivers, not the best single pass they achieved. As shown on the Fast List, beating the Chevy spec even on an owner’s best pass is a difficult task. The Fast List, found at the end of Post #1 of this thread, is open for additions as submissions are received and validated. The Fast List has five sub-lists. Bone-Stock on Stock Tires. This means completely stock with no performance changes whatsoever; must have one of the three stock tires defined in Rule Change (Oct 15 2010) below, stock exhaust, stock airpath, stock “untuned” and ""never-tuned" computer (ECU/PCM), etc. See Posts #469 and #1020 for some elaboration. Bone-Stock, except Non-Stock Tires including drag radials. Otherwise, the same requirement as above. See Post #1020 for some elaboration. Bolt-Ons without Internal Engine Modification (e.g. modified air-path, headers, PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires) Internal Engine Mods plus Bolt-Ons (e.g. stock displacement 427 with bolt-ons plus heads and/or cam) Power Adders (Nitrous, Turbo, Supercharger) and Non-Stock Displacement Rules: In proposing submissions for inclusion on the list, please follow these simple rules Rule #1. Post the details of your quarter-mile pass using this template: Note: your submission won't be acted upon unless it is in the format below. This requirement applies to each new Personal Best. (start cut and paste) Year of the Z06: Tires used on the pass: Performance Mods (if any): Category submitted for: 60'............. 330'........... 660'........... 660’ mph... 1000'.......... 1320'.......... 1320’ mph… Name of the track: Date of pass: Weather conditions: (include Density Altitude, if known): Image of complete Time Slip: Link to Corvette Forum thread containing report: Link to Video: (End cut and paste) Rule #2. Times that may qualify for the top-20 in each category require posting of an image of the complete time slip. If you lack the ability to post an image, contact me via PM, and I will help you. Edit for Clarification (Sep 3 2007): "time slip" means full time slip. Must include date/time of the pass and customarily includes identification of the track issuing the slip. Image should be in the vertical orientation and the numbers must be legible. Edit for Clarification (Jan 10 2011) A time slip is encouraged for all submissions as a means of improving documentation of accomplishments and increasing credibility of the Fast List. Rule #3. Track times will not be corrected for weather or track altitude. Those elements can be noted in the comment portion of the submission to clarify the conditions under which the run was made. If interest merits, we can include a single category for fast times at tracks with altitudes, say, above 3000’ for the official track elevation. Please let us know if there is interest in such a category. Rule #4. All members are invited to submit his/her times on this thread. The top 50 or so for each category will be included in the Fast List. Only one pass per member per car-model per category will be included on the Fast List. Rule #5. In the event two members submit a 1320’ ET identical to the thousandth of a second, the tiebreaker is the higher 1320’ mph. Rule #6. (Oct 20 2010): Stating explicitly a rule applied to all submissions since the Fast List's inception, in order for your track results to be included on it, they must be plausible, probable and credible. The time slip must match the capabilities of the car. Rule #7. (December 7, 2011): Stating explicitly a rule applied to all submissions since the Fast List's inception, in order for your track results to be accepted for inclusion, the registered owner of the car must be driving it. That is, owner=driver. In other words, the driving role cannot be outsourced to someone else. Rule #8. (February 1, 2016): Any naturally aspirated submissions to either the Bolt-Ons without Internal Engine Modification or the Internal Engine Mods plus Bolt-Ons sub-lists which have a nitrous oxide system installed in the vehicle, must have the bottle removed from the car in order for the pass to qualify. We appreciate member support for the Fast List and the moderators' accommodation for making it easy to find via status as a sticky. Rule Change (Oct 15 2010): Stock Tires. "Stock tires" for 2006-to-current-year C6 Z06 now include either of the three factory-delivered tires: GY Eagle F1 Supercar EMT, Front: 275.35ZR.18, Rear: 325.30ZR.19 GY Eagle F1 Supercar G2 RunOnFlat, Front: 275.35ZR.18, Rear: 325.30ZR.19 Michelin Pilot Sport PS2 ZP Front: 285.30ZR19, Rear: 335.25ZR20 No other tires or sizes of these tires are recognized as stock. Clarification (Oct 20 2010): A car with a tuned (modified file) PCM or a non-OEM PCM is not eligible for either of the two stock classes thereafter. This means once tuned, always tuned. ======================================== ===================================== Finally, all of us are deeply indebted to Ricky (AKA '06 Quicksilver Z06) who labored mightily for more than three years to organize and maintain the Fast List. His efforts created the most credible fast driving list on the Web. Widely-cited and never disproved, the Fast List has helped burnish the reputation the the cars we love. God's speed Ricky[size="4"][/size] |
Originally Posted by Ranger
"The Fast List is located in Post-1." ... |
good idea! looking forward to these guys! thanx
I hope I can find this thread on Monday, first chance to get to a scanner. Hopefully my weekend hangover will subside by then aswell.
woohoo!! am i first on list?
my time slip Year of the Z06: 07 Tires used on the pass: 315/35/17 BFG DRs Performance Mods (if any):LPE cai, LG headers, Borla catback, tune Category submitted for: 60'.............1.73 330'...........4.73 660'...........7.25 660’ mph.....97.81 1000'..........9.41 1320'..........11.24 1320’ mph…123.24 Name of the track: Texas Motorplex Date of pass: 7/6/7 Weather conditions: (include Density Altitude, if known): Temp 82, very humid Corvette Forum post containing report original thread btw, thats my best run to date too, i've currently got 70 more rwhp, but can't figure out the launch now :cry |
Originally Posted by Jeenis
(Post 1561646300)
my time slip Year of the Z06: 07 Tires used on the pass: 315/35/17 BFG DRs Performance Mods (if any):LPE cai, LG headers, Borla catback, tune Category submitted for: 60'.............1.73 330'...........4.73 660'...........7.25 660’ mph...97.8 1000'..........9.4 1320'..........11.24 1320’ mph…123.2 Name of the track: Texas Motorplex Date of pass: 7/6/7 Weather conditions: (include Density Altitude, if known): hot, very hot, very humid Corvette Forum post containing report btw, thats my best run to date too, i've currently got 70 more rwhp, but can't figure out the launch now :cry Please edit the trap speed to include two digits after the decimal. That is the format of the list. Also please include a link to your original report of the pass. There is a line for that in the format. I recall reading your post (and replying to it) on the drag racing board. Ranger |
Originally Posted by 07WhiteDevilZ
(Post 1561648011)
Year of the Z06:2007
Tires used on the pass:345/35/17 Performance Mods (if any):cam, ported intake,polished heads, headers, tune, clutch,c5 axles,airfilter,coldair,no cats,160 thermo,ewp,nitrous 175hp Category submitted for:power adder 60'.............1.46 330'...........4.11 660'...........6.39 660’ mph...109.07 1000'..........8.31 1320'..........9.94 1320’ mph…139.85 Name of the track:old bridge township raceway park nj Date of pass:03/31/07 Weather conditions: (include Density Altitude, if known):unknown Corvette Forum post containing report: http://forums.corvetteforum.com/show....php?t=1664861 Please identify the tire brand highlighted in blue above. And verify 345 is correct. Thanks. Ranger |
Year of the Z06: 2006
Tires used on the pass: stock Performance Mods (if any): none Category submitted for: bone stock 60'.............1.85 330'...........4.900 660'...........7.356 660’ mph...100.59 1000'..........9.450 1320'..........11.223 1320’ mph…127.16 Name of the track: Maryland International Raceway Date of pass: March 30, 2007 Weather conditions: (or Density Altitude, if known): DA=200 feet Corvette Forum Post with report: http://forums.corvetteforum.com/show....php?t=1664635 Video: http://www.youtube.com/watch?v=6Y-Fq306rzI Details: http://www.rangeracceleration.com/06_Z06_Stk_Tires.html Slip: http://www.rangeracceleration.com/ho...6Z06.11_22.jpg Ranger |
Tires used on the pass: BFG 315.35.17 drag radial Performance Mods (if any): none Category submitted for: bone stock on non-stock tires 60'.............1.679 330'...........4.625 660'........….7.046 660’ mph…102.61 1000'..........9.114 1320'.....….10.856 1320’ mph…129.50 Name of the track: Maryland International Raceway Date of pass: November 4, 2006 Weather conditions: (or Density Altitude, if known): DA= negative 850 Corvette Forum Post with report: http://forums.corvetteforum.com/show....php?t=1541575 Video: http://www.youtube.com/watch?v=469NvIOiz7U Details: http://www.rangeracceleration.com/06_Z06_DRs.html Slip: http://www.rangeracceleration.com/ho..._1085_slip.jpg Ranger |
all fixed there ranger and i posted photos of slips for a top 10 position.
george
(Post 1561648101)
Thanks for the submissions, 07WhiteDevilZ.
Great Idea..always wondered why the C6 Z didn't have a fast list....:thumbs:
Just got in from Carlisle.
I will work at getting the list updated tonight. Thanks you to those who have submitted their documentation. :thumbs: :cheers: |
Originally Posted by '06 Quicksilver Z06
(Post 1561654806)
Candidates so far are
Ranger...bone stock list Jeenis...Bolt-Ons without Internal Engine Modification list 07WhiteDevilZ....Internal Engine Mods plus Bolt-Ons list Ranger....Bone-Stock, except Non-Stock Tires list. In the process of reviewing the documentation for each candidate. Keep them coming all. :thumbs: :cheers: |
whats up why has this not been sticky up top yet and why was only one of my slips approved is there some questions you have for me
george |
(Post 1561749099)
george |
(Post 1561753634)
No George. I have looked over all of the information you have provided and the list is updated to show your two other times in the two other categories. :thumbs: :cheers:
George still wonder why the mods have not stickyed this yet ? |
1 Attachment(s)
Let me give you one for the "Over 3,000' club":
Year of the Z06:2007 Tires used on the pass: stock Performance Mods (if any): AR headers, Vette-Air intake and throttle body, 160 stat, tune Category submitted for:Bolt ons, over 3000' 60'.............2.13 330'........... ??? 660'........... 8.03 660’ mph... 99.6 1000'.......... ??? 1320'.......... 12.15 1320’ mph… 122.1 Name of the track: Albuquerque National Dragway Date of pass: 8/03/07 Weather conditions: Actual altitude of track is 5320', DA was 8,286', (81*, 50%, 30.12) Yep, we're racing on Mount Everest here. Corrected for DA :10.89 @135.8 A link to the forum posting: http://forums.corvetteforum.com/show...post1561766027 Here is my timeslip: Attachment 48168855 |
Tires used on the pass: Stock F1 EMT Performance Mods (if any):NONE Category submitted for:Stock on stock tires 60'.............1.688 330'...........4.787 660'...........7.288 660’ mph...98.22 1000'..........9.429 1320'..........11.242 1320’ mph…122.38 Name of the track:Atco Raceway Date of pass:11/17/06 Weather conditions: (include Density Altitude, if known): DA=+500 Corvette Forum post containing report: http://forums.corvetteforum.com/show....php?t=1552634 Timeslip |
Originally Posted by 6Speeder
(Post 1561755003)
Year of the Z06:2007 Tires used on the pass: stock Performance Mods (if any): AR headers, Vette-Air intake and throttle body, 160 stat, tune Category submitted for:Bolt ons, over 3000' 60'.............2.13 330'........... ??? 660'........... 8.03 660’ mph... 99.6 1000'.......... ??? 1320'.......... 12.15 1320’ mph… 122.1 Name of the track: Albuquerque National Dragway Date of pass: 8/03/07 Weather conditions: Actual altitude of track is 5320', DA was 8,286', (81*, 50%, 30.12) Yep, we're racing on Mount Everest here. Corrected for DA :10.89 @135.8 Need to see your time slip. Thanks. :thumbs: :cheers: |
