Octane Requirements 1979
I don't want to open too big a can of worms here but..
My new to me 79 came with all sorts of documents and factory manual but no owner's manual. What is the recommened octane level for the 79 L82 engine, been using high test to be safe? Adrian |
1979 Unleaded Fuel
According to the Owners Manual, Page 5-1, "Your gasoline engine is designed to use ONLY UNLEADED gasoline. Unleaded gasoline must be used for proper emissions control system operation." There is no mention of the octane requirement. On Page 7-2, the Compression Ratio for the L-82 engine is only 8.9 - 1. My guess is that the car would probably run on regular, but to be safe, a mid-grade or premium, would probably be better. Maybe someone more familiar with the engineering aspects of engines could shed more info on this.
Your 79 will run on 87 which is regular. if it pings run the next higher octane. it can't hurt to run premium most do and the cost is less then a $1.80 more to fill the tank w/the good stuff.
If I remember correctly, there was no such thing as 'super' unleaded in 1979.
Your only choice was what we now call 'regular' unleaded, or 87 octane. |
In '79 you could still find stations that had upwards of 100 octane (if you knew where to find them). But your '79 C3 only needs regular unleaded gas. As mentioned, if you get some pinging, adjust the advance or buy the mid-grade of gas. Premium gas in that car is a waste of money, IMO.
I understand regular will work assuming stock timing..
But What about those that have the timing advanced per the Lars Papers? Does that make any differance? I use premium anyway and don't mind wasting the money that way as I find many other ways to waste it on this car. lol |
Regular 87 octane is fine.
If it pings, you have 2 choices; retard timing or switch to higher octane. |
Just to help clarify.... Lars instructs us as to the BEST way to set up your engine for best performance and operation. The factories DIDN'T set them up for optimum performance for two reasons: 1) it took more time and, therefore, cost more to do; 2) retarded timing might generate less emissions, but it definitely produces less power...which translates to LOWER WARRANTY COSTS. Lars knows that your engine can operate properly (better, IMO) when mechanical advace is set to 34-36 degrees max and when it all comes in around 2500-2800 rpm. The engine is designed to handle that and not ping. GM didn't go to that trouble. I just had Lars redo my carb and distributor for my '71 [low compression] engine. It never ran better since I've had it, it doesn't ping on regular gas and it is more economical than before. What's not to love?
My 80 was to run on 87, but I rarely did. My crate is also to run on 87. Ive only put 87 in once and didnt think it was worth the risk. When fuel is in the $3 range, what is another 20 cents....:willy:
Just my opinion |
Originally Posted by Adrian Chadwick
(Post 1561620549)
...My new to me 79 came with all sorts of documents and factory manual but no owner's manual.
Higher octane = higher horsepower = better power performance = more $$$. Higher octane will not hurt the car (other than you will wear the engine out sooner). Lower octane will not hurt the car as long as it is not pinging. Use whichever you like for your "reasons".
Is this the same for a 77 with an L82????:bigears
Originally Posted by VettePower
(Post 1561637348)
Run the lowest octane gas that doesnt allow detonation (ping) anything more doesnt improve performance and just spends your money.
If you modify the engine, the same holds true...higher compression - more advance - run whichever octane eliminates ping..(probably a higher grade)..but dont run any more than you need...thats just money down the t*let. no harm will come to your engine if you run higher than necessary octane, but all things being equal, higher octane will not improve performance unless you need it. |
Originally Posted by 7T1vette
(Post 1561637060)
:bs I can't believe that this myth is still around.:nono: |
(Post 1561625606)
Mike,
1) Please explain how a higher octane fuel..with better burn characteristics...would NOT generate more power out of an engine. 2) There were lots of (older) C3 cars that didn't have catalytic converters in 1979. The statement made above was that no such "hi-test" gas was available in '79. Not true. |
(Post 1561647001)
Mike,
1) Please explain how a higher octane fuel..with better burn characteristics...would NOT generate more power out of an engine. 2) There were lots of (older) C3 cars that didn't have catalytic converters in 1979. The statement made above was that no such "hi-test" gas was available in '79. Not true. http://en.wikipedia.org/wiki/Octane_rating http://chemistry.about.com/gi/dynami...tos/octane.htm The availability of high octane gas allows either OEMs or home builders to configure engines with higher compression ratios, more adventurous ignition maps and/or cam characteristics. It is these features in the engine that produce the increased power, not the gas itself. 2) Please re-read my post. I said no super UNLEADED gas in 1979. There was plenty of leaded super gas available, as well as regular leaded. If you had super unleaded available in your area, that's nice. None was available here. |
There was unleaded (regular), low-lead, and leaded. Sunoco 260 was 103 octane and leaded.
Paul,
Do you remember when hi-octane unleaded gas became widely available? I'm thinking mid-late 80s? |
