Difference in R70 vs R75 tires?
Is there a noticable difference in the width of a R70 series vs a R75 series tire? I would like to replace my 6.70 x 15's with a 205 x R75 X 15. I seen on Coker's site they have only 205 xR70 x15's.
Any recommendations? Thanks |
The width of an R70 and an R75 should be the same -- in this case 205 millimeters -- about 8 inches. The difference will be in the height. The sidewall of a 70-series tire will be 70% of the width, a 75 series will be 75% of the width. If you want the same HEIGHT in a 70 series, then you need to go wider in the width -- about 219. Of course, they don't make 219...
a 215 will be a little wider and a little shorter, while a 225 will be even wider, and a little taller. Frank |
205 is the mounted width (in mm) of the tire on a particular rim width (probably 6" for a 205)
R is for Radial 70 (or 75) is the ratio of the width to the sidewall height. 15 is the rim diameter So a 75 will be a taller tire, and closer to the height of the 6.70x15. If you go 70 then a 215 will get you closer to correct height I see Frank (decarmine) answered at the same time I did!! |
thanks for the information.. Will 215's fit on a '63 Vette?
205 70 15 = 8.1" wide 5.7" tall Side wall 26.3" height
205 75 15 = 8.1" wide 6.1" tall Side wall 27.1" height 215 70 15 = 8.5" wide 5.9" tall Side wall 26.9" height 225 70 15 = 8.9" wide 6.2" tall Side wall 27.4" height These are generic calculations as all tire manufactures are different. |
Of further interest to you is the spare if you elect to carry one. If the size does not match what's on the ground if you get a flat on the rear you should rotate a front to the rear installing the spare (odd size) on the front. This is only important if you have posi.
I have 215/70's all around mounted on 15x6 knockoffs. The tire fits in my spare tire tub using the longer hanger bolts. This gives a slight exposure of the spare to the elements. |
The Diamond Back 205/75-15 Firestone Supreme Si tire has about a 1-1/4" wider tread than the Coker 205/75-15, and doesn't look "skinny" like the Coker and the original 7.75-15's do; no rubbing under any conditions, no problems, they balance, and they're round. :thumbs:
http://img.villagephotos.com/p/2002-.../DBRedline.JPG :cheers: |
I also have 215/70's all around with no problems. I would caution you to check the archives for a lot of material on Coker tires. In short, most folks think that they are junk compared to the Diamondback. I have had both, and I would not take another set of Cokers if they were free. The Diamondbacks that I have now are great.
Doc |
