"The security light remaining on is a sure sign of an under hood ground issue. Been there! Clean ALL of the under hood ground connectors and frame contact points. See my IMPORTANT ELECTRICAL INFORMATION sticky."
Where do I find this information? I have a 99 that is just starting to have FOB problems. Thank you! Rowland |
Originally Posted by slick56
(Post 1562079967)
Where do I find this information? I have a 99 that is just starting to have FOB problems. Thank you! Rowland http://forums.corvetteforum.com/showthread.php?t=896875 BC |
Finally!!!!!!
OK checked everything, did everything recommended, (THANKS EVERYONE FOR THE HELP) but ultimately bought a new FOB and viola all is right in Zora Land!
Judging by the number of FOB's on Ebay and the expense for a new one relative to other Vette model years it's not an uncommon problem. Good luck and...... THANKS AGAIN EVERYONE FOR THE HELP!!!!!!!!!:cheers: |
I know you got a fob, but for others:
Check out Gene's prices? His Nov Specials are in General. ||--Genuine GM Key FOBS/Transmitters--|| 10253839 – 97-99 – 67.20 10432147 – 00 –04 - 55.20 |
Originally Posted by Oldvetter
(Post 1562723045)
Originally Posted by lakedude
(Post 1561795263)
I went to Gene's but can't find the FOB in the parts to save my life. What does FOB stand for anyway? I tried a search but it comes back with Geo parts???
A key fob is a decorative item many people often carry with their keys, on a ring or a chain, for ease of tactile identification, to provide a better grip, or to make a personal statement. Key fobs are often mistakenly called "key rings" or "key chains" in colloquial usage. Fobs vary considerably in size, style and functionality. Most commonly they are simple discs of smooth metal or plastic, typically with a message or symbol such as that of a logo (as with conference tchotchke) or a sign of an important group affiliation. A fob may be symbolic or strictly aesthetic, but it can also be a small tool. Many fobs are small flashlights, compasses, calculators, penknives, discount cards, bottle openers, or USB flash drives. Electronic key fobs are used for remote keyless entry systems on motor vehicles. Early electric key fobs operated using infrared and required a clear line of sight to function. These could be copied using a programmable remote control. More recent models use challenge-response authentication over radio frequency, so these are harder to copy and do not need line of sight to operate |
used vs old
In all honesty the amount of money I saved buying a used "FOB" probably isn't worth the money saved. If it breaks I'll need another (obviously) and likely is a good chance it'll quit soon as they seem to be a hot commodity and topic on this forum.
Bottom line if I had to do it all over again I call Gene and get a new one. Odds are I will be soon anyway.:ack: |
