Comp Cams- CS EX274H-10 extreme series.
Anyone heard this cam in a SBC yet.
The web site doesn't really say if its rough idle or what, just good mid range torque. int-487/ex 490, dur 274/286 on a 110 lobe sep. |
I'm running that cam in a 383 and it idles with a lope.. Sounds good and it idles below 1000 rpm with no probs at all.
I want a lopy sounding cam, I have the 470/270 Comp cam now and its too tame. Either the 274 extreme or the 480/280 comp cam I think would sound good.
I really like Crane, but their cam site isn't very good compared to Comp so I ruled them out. |
Need to know engine size/specs to even begin a response here. In my 406 the Comp XE-274 idled like a stock 350.
The web site doesn't really say if its rough idle or what, just good mid range torque. int-487/ex 490, dur 274/286 on a 110 lobe sep. I want a lopy sounding cam, I have the 470/270 Comp cam now and its too tame. Either the 274 extreme or the 480/280 comp cam I think would sound good. I ran the 292H Magnum (.501"-lift, 244* @ .050", 110* LSA ) on the street with a 'tight' 10"-converter to/from the strip (10.3:1 355" SBC ), and it wasn't that-bad..... |
Originally Posted by The Money Pit
(Post 1561382479)
(Post 1561382324)
I really like Crane, but their cam site isn't very good compared to Comp so I ruled them out. How about this lunati, cam and lifters # LUN-60104LK. lift 504/525, 276/284 dur, 110 LSA. not hairy enough, # LUN-60105Lk, lift 525/546 dur. 284/292 LSA 110. |
(Post 1561382324)
(Post 1561382324)
470/270 is a very nice/good cam with a noticable healthy sound to it.
I am just going to pull the engine and trans and do some fun high performance things to it, like a 3500 stall and new 350 race prep trans, heads ETC so I want a lopy cam. The 470/270 makes alot of power!!!! |
3500 stall, more comp. very good, go for that 2nd lunati, lots of
lift for a 280s duration hydraulic flat tappit cam. :thumbs: Hell I had a 270 crane in my 350 pickup, stock converter, power sucking turbo 400, 3.07 rear gears. |
(Post 1561380073)
The web site doesn't really say if its rough idle or what, just good mid range torque. int-487/ex 490, dur 274/286 on a 110 lobe sep. I have honestly been having a little trouble with idle in gear. But, I've been working with Lars on timing and vacuum advance. I ordered a new vacuum advance per his recommendation and hope to correct the idle. The cam is good off the line but even better about 30 mph and stomp it. I have vortec heads, edelbrock intake, q-jet. 2,500 torque converter. I like the cam just fine. Good luck, Doug |
Originally Posted by ddale1977
(Post 1561403137)
I have this cam in my 350 auto. The machine shop said its going to 'sound like a corvette should'....(whatever that is). It does sound real good with my hooker sidepipes/headers. Get a lot of complements pulling into a parking lot.
I have honestly been having a little trouble with idle in gear. But, I've been working with Lars on timing and vacuum advance. I ordered a new vacuum advance per his recommendation and hope to correct the idle. The cam is good off the line but even better about 30 mph and stomp it. I have vortec heads, edelbrock intake, q-jet. 2,500 torque converter. I like the cam just fine. Good luck, Doug But until then, you will spend more and more on distributar parts vacuum line and canisters and plug and unplug every vacuum port on the engine and carb until you strech the timing chain 10 degrees negetive and have to start over. But heck I haven't had to raise the hood of mine for weeks now, but some call it exsercise:crazy: |
I'm running that cam in my 383. I'm very happy with the sound. A bit of a lope, but it doesn't sound like a full out race car either. Pretty good performance for a hydraulic flat tappet without crazy lift or duration. (See my signature...)
:cheers: Bob |
I'll dissent. I think the XE line is poorly designed. First, with good heads and good exhaust, dual pattern will cost you ponies. Here's some good reading:
http://www.camaros.net/forums/showth...hlight=cabbage Secondly, many XE cams fail on start up. The ramps are too aggressive for a flat tap cam. And many of those that do survive start up, report too much noise (noise = friction,..slapping valves, etc). Go to www.chevelles.com and www.camaros.net and do a search, "noisy XE cam". You'll get a 156 hits on the Chevelles page and 115 on the Camaros page...(what would we do without the internet?...believe the marketing hype?) I would stick to the 270H or up to a 280H. Or better yet, go roller. Lastly, how a cam would sound should be a distant concern for the street or heck at the track. It would be easy to pick a great "sounding" idling cam that ran very poorly when things got serious. |
I would like to know why more people seem to flock to comp cams ??
Originally Posted by Little Mouse
(Post 1561407263)
For my 406 build....I choose POWER BY CROWER. :thumbs: Eddie |
(Post 1561407263)
And yes sound is important, if not then I would stick with factory and run 150 shot of NOs. |
what about the new comp cams thumper hyd roller cams they sound killer!!!
(Post 1561418553)
They have a good web site that puts the cam numbers big in your face , unlike Crane.
And yes sound is important, if not then I would stick with factory and run 150 shot of NOs. random, no reason for picking it. Part #110591 grind# H-22813200-25-6 1957 to 1987, chevy 262-400 cu description performance usage, good mid range torque and HP, bracket racing, street, heavy, ect., auto trans W/3000 converter, 10.0 to 11.5 compression ratio advised, basic RPM 2800-6200 valve settings, hot, intake .000 exhaust .000 lift at the cam lobe, intake 3200 exhaust 3294 valve lift intake 480 exhaust 494 rocker arm ratio 1.50 LSA 106 cam timing at .040 tappit opens, intake 36 BTDC exhaust 71 BBDC closes, intake 68 ABDC exhaust 39 ATDC advertised duration, intake 284 exhaust 290 Cam Timing at .050 tappit opens, intake, 12 BTDC Exhaust, 47 BBDc closes, intake, 36 ABDC exhaust, 7 ATDC Duration intake .050 228 exhaust .050 234 recomended RPM range, with matching components 2800 6400 7000 valve float Spring requirements part # 96802 closed 107 lbs at 1.800 or 1 13/16 height open 289 lbs at 1.330 All this is at one place for this cam on cranes web site. Crane has the opening and closing for you at both .040 tappit and .050 tappit, now if the other cam companies have more info, my hats off to them, buy there cam. |
