Tech 2, can do?
Can you reset the temps at which the fans come on ( and percentages) useing a tech 2?
GM |
Sure can
You can only command the fans on/off with the Tech II and candi module hooked up to the vehicle. You cannot reprogram the fan temp settings with the tech II.
EFILive's V2 FlashScan can program fan settings on a C6. (It can also disable CAGS!)
I'd buy anything on the market if it could turn TM and TPS all the way off.
Yup!
why not buy a handheld like predator or something. Tech2 is expensive.
Don't plan on buying anything. A friend who is a mechanic has a tech 2, and I just wanted to know if it was possible to reset the fan temps with it.
GM |
