Originally Posted by TexasYankee
(Post 1596722117)
I know this is an old thread but I wanted to say thanks to the OP. I fixed the window in my 2001 Vert this weekend using his instructions. I spent $8 and saved $1500. This thread ought to have been stickied years ago.
Back glass
This rhino glue does it hold up and is it a one man job
Originally Posted by John001
(Post 1597075848)
Who i learned from.
(Post 1597075848)
For the directions i followed picture by picture line by line Go to CorvetteForum Threads enter... His username is.... enter gem Convertible reawindow How to re fasten gem picture by picture he posted is so easy to follow a Caveman can do it. The suction cup rope method is brilliant. I didn’t have garage roof joists in FL. so i did it in the FL shade on a 80 degree day. i used suction cups on the fiberglass tonnaue cover and the handles of the suction cups with towels to prop the window into place then 1/8 inch bead RHINO GLUE on the rubber seal on the top 2 to 3 inches at a time. Overlapping a 1/4 in. at a time. I drove it in all weather until then. Learning i wont drive it below 30 degrees. Ive had to many failures in below 0 weather especially 20 25 below I experienced trans and rear end leaks. Having the dealer replace all the seals trans and done at a 100k. They have the pump to empty and fill the trans. Then run it on a lift for 15 minutes in drive stop it and pump the last i don’t remember 2 or 3 qts into the trans. Good luck with the window. John |
One more thing.
Originally Posted by km60sb@yahoo.com
(Post 1597076693)
Hi John. I did mine on my 02 C5 vert. 3 years ago April and redid it almost to the day. About 50% failed. Driving highway speed it failed a little bit at a time. Was an everyday car. It lives in southern FL Jan thru May. MY tops window fell out 75% AT 90K 1st time. I re searched for a week mostly on utube sites then mostly CF.
Hey everyone! Hope 2021 is looking up for you all. Or at least better than 2020. I'm resurrecting the thread. My 06 vert has a similar problem, but with a twist. The window itself seems to be holding in quite well, even at 16 years, but the rubber bezel that holds the glass onto the fabric is letting go of the glass, at the bottom of the window. Almost as if the fabric between the bottom of the vert window and the bottom of the fabric top is shrinking. I'm getting water intrusion into the interior, as it appears water is going around the glass window through the failing seal on the bezel. Does the Rhino Glue flow well enough to get into the very tight space between the glass and bezel, and seal out water? Any help would be really appreciated!! Stay safe and healthy, one and all.
FOLLOW-UP: It has now been over 11 years, and the 3M Urethane Window Weld is still holding strong. Probably because it is the correct adhesive for the job!
Hope this helps someone. |
Rhino glue is a liquid that flows but you only have a short time to play with it - plan on 30 seconds or less before it starts to solidify - similar to super glue.
Do it
You can do this. It’s an easy fix and I’m no mechanic. I got a $1500 quote for a new roof. Instead, I bought Rhino glue and $40 set of suction cup clamps from Amazon.
I didn’t do the pulleys but with big comforters stuffed inside against the glass, I glued the loose edges carefully to be sure to get no drips on the window itself. I put the clamps in and left them there for 48 hours. I’m happy to say it’s been holding for months now, even driving in the rain. of
Originally Posted by NJ01vette
(Post 1563925035)
Sorry to bring back an old thread, however this just happened to my vert today at the car wash :ack:
I need as much help as possible with this, can anyone post thier 2 cents, and give me some advice on any other way to tackle this project..suction cups and pulleys, I'm a pizza guy, not a mechanic, nor do i pretend to be. Any help would be great.:willy: |
Your Rhino Glue recommendation was AWESOME!! My rear window completely fell out the day the Rhino Glue arrived from Amazon. It only took 2 hours to fix.
My roof has two straps that keep the window positioned within two inches after it is completely detached. BTW. I propped the roof to loosen the tension with a 16 oz bottle of milk. Under the center of the window, I positioned an inflatable neck brace to position the window then glued a segment at a time: bottom, left side and top, right side. I stuffed a shop towel roll where I was pressing for glue curing 60 seconds. The Rhino Glue Dispenser is made for a thin bead. Do not squeeze too hard or dwell to make a thicker bead, the thin bead is perfect and did not leave any over spill to be razored off. 1 hour later PERFECT!! I locked down the top. There showed two suspect areas. They could have been stuck further back, but I re-propped the roof and added glue to both, they were on the lower left corner and upper right corner and, again, used the Shop Towel roll to support the window while I pressed the roof and window together for 60 seconds. I have not water tested, because I don't drive my C5 in the rain or park it in the rain without a cover, however, I have tried to pull the seal everywhere and there are no loose spots at all !! Thank you so much for the Rhino Glue recommendation!! |
Originally Posted by c7pilot
(Post 1603033613)
1 more tip that worked for me. I used 3 or 4 of those bathtub/shower suction cup handles, you know, the ones with a suction cup at each end and the handle runs between them. They're cheap, available at WalMart, and the cups are each about 2-1/2"-3" diameter, and the handle between them is like 5" long. Hope this helps someone. Take your time, think it through, and you can do it!!!
Rhino Glue - great - for a while
My luck was not as good as some. I did the rhino glue thing. Cleaned everything the best I could, propped the top open a bit with a piece of two by 4 and put a thin line of glue around the edges of the window. Then pressed it together and put bolsters in side to push against the window and used a set of ratchet straps from my fender opening to a board I laid across the rear window with shop manuals between the board and read window for pressure. This worked for 2 years. I knew I had a small issue right at the beginning because I heard a sound sort of like Velcro when I first closed the top. It was pretty hard to do on the passenger side. I am guessing I did not prop the roof open quite enough. That might have been my downfall, but I am not sure. I tried to do it a second time but it was impossible to clean all the dried glue from the roof material. I did the best I could and glued it again but that time it only lasted for a few months.
I gave in and had a new top put on not long after that. I was done fooling around with it. I had new seat covers put on by the shop with new foam at the same time. I like what people are saying about the 3m window weld, though. I would try that if ever asked to help someone else with the problem. The good part is that the new top has a better method of attaching the window and top (I believe they used that on the 04), so I am hoping this will be the last time I have to mess with it. |
Thanks GEM, I took your lead...
My rear window fell in completely with only the 2 cloth upper and 2 lower straps keeping it from being totally free. I purchased a dual suction glass lifter from Harbor Freight for $9.I bought the the same Rhino Glue from Amazon. I too strung some line to the garage ceiling from the glass lifter through the hook and back. Since my window came completely out I had to glue the entire perimeter so that meant I had to have everything ready except for the gluing. I went to side of car and glued 2/3 of the window and hurried to the other side to apply the rest and pulled the rope and handle up to seat in place. I also stuffed 2 old pillows in each corner to help keep the window pushed against the top.
https://cimg4.ibsrv.net/gimg/www.cor...24d296325c.jpg I placed a laser on the rear window aimed to show approx. where I needed to install a garage hook in the ceiling. Luckily I found a stud close to the spot. https://cimg1.ibsrv.net/gimg/www.cor...003e1709e7.jpg Glued and set. Next time I need to use a non-fiber rope as this left little fibers everywhere. Hopefully I won't need to. Note the pillows stuffed in the corners. |
That is a good overall explanation of what you did. I wonder if the high-performance hot glues with a long open time would work for this kind of repair. For example, there are glues that are used by flooring installers, as well as auto body shops.
I realize that you have about $25 to $30 in your repair, and I hope you get excellent results. And welcome to the forum. |
Thanks Sam!
Originally Posted by Sam Handwich
(Post 1603833482)
That is a good overall explanation of what you did. I wonder if the high-performance ho glues with a long open time would work for this kind of repair. For example, there are glues that are used by flooring installers, as well as auto body shops.
I realize that you have about $25 to $30 in your repair, and I hope you get excellent results. And welcome to the forum. https://cimg7.ibsrv.net/gimg/www.cor...3c7a1e27d4.jpg My 2002 C5. |
To all the vert loosing their rear glass and not willing to go the rhino glue, a product is made to glue plastic on glass, stay flexible and water tight, it is 3M VHB VHB tapes. It is sold as a double sided tape, so you have plenty of time to do the job peacefully, and it will absorb some of the tensions of the roof when it is locked in place.
TCFS https://cimg6.ibsrv.net/gimg/www.cor...ae24adca6.jpeg |
I have the VHB product and have used it in numerous situations. Had not occurred to me to use it for this, but makes all the sense in the world. Will file the suggestion in my mind.
Thanks for the idea. |
(Post 1603033613)
Kinda sad that we "backyard" engineers find something that may work better than what the GM engineers used.......
