Need advice on how to wash vette...
My new vette needs its first wash. I have Meguires car wash solution, and I'm planning on using my leaf blower for the drying process. What type of sponges, towels, detailer do I need? What is the correct application techniques and steps? I've heard that the swirl motion is NOT the correct way to wash and/or apply detailer to car. Any help advice would be appreciated. Thanks.
Welcome and look around this section.
Supplies:
-car wash soap with high lubricity -high quality sheepskin wash mitts -foam gun (optional) -2 buckets with grit guards for paint -1 bucket and mitt for wheels -high quality microfiber towels -210+ mph electric leaf blower -high quality sealant and/or wax -quick detailer Method: -Wash wheels/tires/wells first to prevent spotting on paint and glass -Don't use the same mitt or bucket for wheels that you use on your paint. The brake dust, etc. from your wheels will cause scratches and swirls in your paint. -Using foam gun, cover vehicle in a thick layer of foam (optional) -Use two buckets for washing paint. One with a soapy mixture, the other with plain water to rinse the mitt between panels. -Never use circular motions. Always wash, dry, and wax using front to back and top to bottom motions. -When vehicle is fully cleaned, allow a slow, steady stream of water to flow over each panel...sheeting the majority of the water off -Use the leaf blower to blow all water from flat surfaces, mirrors, lights, etc. -Remove any remaining water with a waffle weave drying towel and detail spray *The less you touch the paint, the less chance of marring* Keeping a good sealant and/or wax on the paint will assist in cleaning and reduce chances of marring. |
cvowner,
Congrats on the new Vette!!! For some washing and detailing tips, check out these instructional videos: http://www.adamspolishes.com/t-videos_entire_video.aspx. They should help to guide you in the proper direction as to what techniques and steps to use. Thanks and let us know if you have any questions:thumbs: ! |
Thanks for the tips. :cheers:
I've had GREAT success with the following system:
At the end of this process I have a clean car with zero waterspots and zero spiderweb scratches. Note that the only thing that touches the finish (besides water) is microfiber (one towel to wash, another to gently dab off any remaining drops of water after blow-drying). Technically, I could skip the blow-drying and final wipedown since the Mr. Clean system is designed to provide completely spot-free air drying. I added those two steps because the water where I live is extremely hard and I was still getting some spotting. Now that I blow-dry and gently wipe down afterwards, I don't get any spotting. I can't over-emphasize how effective this process is. It's the only way my Corvette has ever been washed since new nearly 2 years ago and it has ZERO spiderwebs in its finish. Mr. Clean AutoDry + microfiber cloths = no damage to finish! |
Originally Posted by Dale@Adams
(Post 1560401064)
cvowner,
