inline fuel filter on a 1979
I would like to put an inline fuel filter on my 1979, but I was told you can't do it on a 1976 and later because special fuel filters with anti-spillage valves are used.
I have 2 questions,first what are anti spillage valves and secondly, where are they located? |
Anti-spillage valve? Your fuel filter is inside the carb if it's stock & it has a check valve..........
Why do you want a inline filter? |
Originally Posted by SEVNT6
(Post 1560010003)
Here's the link for making a hard-line with inline filter:
http://wiki.corvettefaq.com/index.ph..._O-Ring_Filter No idea what an "anti-spillage" valve is.... |
You don't need - or want - an in-line filter with a Q-Jet. The in-carb filter flows plenty and is all you need.
The filter in your carb has a checkvalve in it. This valve was originally intended to prevent fuel spillage in event of roll-over and fuel line rupture. It probably doesn't function too well in its intended role, but it does work well to prevent the common Q-Jet float bowl drainage when the car sits overnight. Highly recommend you keep the in-carb filter and not use an in-line. Leave the in-line filters for the Holley and BG carb users who do not have in-carb systems. (Point of interest trivia: Do you know that the stock in-carb paper filter will actually prevent sugar from getting into the engine if someone puts sugar in your fuel tank? The common in-line filters using filter screens will not stop sugar...) |
thanks for all the info i think i will stay with what i've got
