C6 oil pan in C5
Is anyone using the C6 LS2 oil pan to replace the batwing C5 pan for additional header clearance? Is any ground clearance lost with the deeper C6 pan?
Pros or Cons on the swap? |
i will let you know by monday,i am picking up a c6 oil pan tomorrow and i will put my z back together on sunday
:bigears :lurk:
There are no issues with this.
Contact Valvegod if you need one. |
I run a C6 oil pan...
I wish I would have made the switch when I had the TTiX and forged engine put in....it would make the started a lot more accessable :willy: :willy: :willy:
Will the C6 Pan also work on an LS1/6 block?? What are the advantages to it??
Would love to know more on this mod. ttt
The LS2’s new oil pan was developed to ensure oil delivery commensurate with Corvette’s high-performance capability. Extensive track testing has shown the new design to provide better oil control under the extreme demands of high-rpm/high g-force driving maneuvers. The elimination of the previous “gull wing” oil pan design also reduces the engine’s oil capacity from 6.5 quarts to 5.5 quarts with a dry filter. |
:lurk:
Originally Posted by chriswtx
(Post 1560128721)
LS1/LS6/LS2 they are all the same. Use away. This makes turbo access much easier. But as far as it being an "upgrade" I don't see what advantage there is. Working on the TTiX stuff with it is soooo much easier. |
So for a blower car its not really an upgrade from my stock pan??
(Post 1560131179)
It is nice on the X kit stuff because of the open access it gives you to everything, I guess there may be some other benefits if you road raced the car according to what you found, but I don't know of anyone having problems with a C5 batwing bat, so why change it. |
For anyone doing this I believe you not only need the pan, but the LS2 windage tray and pick-up:cheers:
I heat wrapped my uncoated LT headers where they pass next to the wings/oil filter on my pan. I personally noticed a slight reduction in oil temp. I also feel uncoated LT heat will negatively affect the starter/solenoid and therefore the heat should be controlled. I personally have had problems with my solenoid that I attributed to LT heat.
Originally Posted by SpeedyD
(Post 1560132358)
What is the going price for the ls2 pan?
APS owners/installers would also benefit from the ls2 pan; sacsrpc, as previously posted, contact valvegod
Originally Posted by sacsrpc
(Post 1560145886)
