Alternator bracket for headers...
Anyone know where I could find a quality alternater bracket for use with headers? I need one for a 65, passenger side with a small block. I'm going with the hedman headers, but their brackets look pretty cheap. I've had similar brackets before that always cracked. Thanks!
Something like this?
http://i81.photobucket.com/albums/j2...altbracket.jpg There are many choices.................... http://store.summitracing.com/egnsea...115+4294840116 |
Originally Posted by Dicecal
(Post 1559286334)
http://store.summitracing.com/partde...0&autoview=sku |
Thanks!
I went the other direction. I took a set of headers off a '66 small block l-79 and found myself looking for the correct bracket to use in conjuntion with a set of stock exhaust manifolds. I removed an aftermarket alternator bracket with a part number 3951337 with the headers, which is a heavy metal bracket. It seems this part number is common for '72-'82 corvettes. After putting everything back together with the correct bracket the alternator which is not original, fit perfectly and needed no change in even the belt size. I suspect the bracket would work in your instance if the '65 are close to the '66. Not chrome, not polished but pretty heavy duty. If you would like a picture let me know.
Steve :thumbs: |
Originally Posted by cookie_monster
(Post 1559289407)
Hedman part # 20020 is the thickest one I've seen. There are twice the thickness of the cheap chrome ones that all speed shops carries. Black paint is poor though.
http://store.summitracing.com/partde...0&autoview=sku It can be beefed up with a few triangular gussets and a welder, also, it you want it more rigid. Doug |
Originally Posted by r66stingray
(Post 1559290905)
Steve :thumbs: |
i guess i'm still a cheerleader for Alan Grove. call and ask Greg what they have.
Bill |
Originally Posted by wmf62
(Post 1559291936)
Bill |
Originally Posted by AZDoug
(Post 1559290961)
That looks like the same bracket that I have and it has worked for almost 30 years.
It can be beefed up with a few triangular gussets and a welder, also, it you want it more rigid. Doug You're a genius:thumbs: . Why didn't Hedman or Hooker think of your triangular gusset idea? If anyone knows of a source for a "heavy duty" stainless steel bracket, please holler. I realize I can have one made, but I'm sure it will be too costly. |
