Intake Manifold not Sealing?
Hello Everyone – I recently replaced the intake manifold gaskets on my 1972 LT-1. Everything was fine for the first few hundred miles but now I notice some coolant pooling around the second bolt in from the passenger side front (next to the heater hose connection. The bolts are torqued to the proper spec. Any ideas what I might be causing this and/or how to fix (maybe replace the intake gaskets again but I am not sure what I may have done wrong the last time)? Any thoughts are appreciated - Thanks
Are you sure it's not the heater hose adapter leaking where it threads to the manifold or the hose connection itself?
Originally Posted by Mikef714
(Post 1559221588)
Originally Posted by 80TexasC3
(Post 1559221759)
Did you put some RTV around the threads before inserting the manifold bolts? Is recommended and really helps.
Thanks for the suggestions. I will check the heater hose. I did use a small amount of silicone around the water jackets and used the specified torque value and sequence contained in the repair manual I have.
(Post 1559222964)
I believe some of the intake bolts go into the coolant passage way. You need to seal the threads on the offending bolts.
Remember, when you use a sealant of any type, make sure to clean any excess, as to not get any in the oil passages. Pro's know this. Save your motor.
