1963 340hp intake carb air cleaner distributor
I am selling a complete 1963 340 set up
Restored correct carb correct dirstributor correct intake correct air cleaner Here is the photos and numbers of the Corvette manifold, carb & dist. Dist. 1111069 Delco Remy 2 C 10. Carb. base 3E43721, linkage 181-309, tag 72-1S 3851761 DD, bowl Carter AFB and top 6 1518. I will not break up the set. Please do not ask. Complete $1700 |
What is the casting date on the intake? I've got an October build vin and need intake & carb (all you've got) if the numbers work. Let me know, please. Thanks,
Reed Flickinger |
The casting date on the intake is under the oil shielding and I will not pull it off. Does a date really matter if you can not see it?
oWEN |
Ok, I'll play. What is the date on the distributor?
Thanks, Wayne |
Dates and codes posted.
Thanks oWEN |
