Burning rubber smell from heater vents???
I know this is a complete shot in the dark, but figured it couldn't hurt to ask.
Has anybody else had a burning rubber smell coming from the heater vents? I don't smell anything under the hood, and even when driving don't smell much of anything. Soon as I kick on the heater vents I get a strong burning rubber smell. I have done a quick inspection under the hood to mak esure no belts/hoses are rubbing or burning and don't see anything. Other than that what else could I look for??? Thanks in advance... |
I'm actually getting an almost electrical burning smell in my 2002. i cant pinpoint it though and its making me worry.
Originally Posted by jbauch357
(Post 1558971580)
If not an auto, burning clutch smell?
Originally Posted by Texan1Z06
(Post 1573447137)
Burning smell from the heat vent
Originally Posted by Marine One
(Post 1573459301)
Manual but it is definitely not a clutch smell.
Possibly your heater core could be beginning to fail. But typically when they fail you'll see a residue/film on the W/S when on the defrost setting.
I'm saying you have a wire burning. Check around headers and alternator
I had the same smell and could not track down the source. One day while I was changing the oil, I discovered that the drivers side O2 sensor wiring touching the manifold pipe underneath the car. Only the sheathing was a little melted but the wires were still intact. I simply zip tied it out of the way. Problem solved.
