-   C4 Tech/Performance (https://www.corvetteforum.com/forums/c4-tech-performance-48/)
-   -   car stalls after bypassing vats! (https://www.corvetteforum.com/forums/c4-tech-performance/1621779-car-stalls-after-bypassing-vats.html)
all show and more go 02-11-2007 06:37 PM
well a few days ago i was having problems with the car so i disabled the vats by splicing the wires behind the center councel and now the car starts but cuts off after like 2 sec. what can this be?
AGENT 86 02-13-2007 09:18 AM
VATS needs to be disabled in the chip or bypassed with the correct resistor at the bottom of steering column. Sounds like you bypassed the start enable relay. :lurk:
TPI84GMC 03-13-2007 12:47 AM
get the painless module to bypass it if you are sure that VATS is the problem
davidnclearlaketx 04-11-2007 12:28 AM
Take your key to the dealer to find out your VATS code.
Then order the bypass module from Mid America, Ecklers or elsewhere.
As stated above the VATS connection is found by removing the panel below the steering column. Instructions will be included with the bypass module. At least it should be.
:cheers:
