Originally Posted by Highhat
(Post 1558750478)
They recommend it for durations over 220 degrees and mine is 270 degrees @.050 :lol: |
Originally Posted by Marks69BB
(Post 1558756978)
Doug - The 572 crate you refer to most likely has a mild hyd roller for the street.
The new cam will be a solid roller with 262 @ .050, .715 lift. In a 555 I would think, unless the Demon can actually flow over 1000 cfm, it won't be enough. As I asked before, can it be modified to flow more? And if not, what would be your recommendation from the Demon line? Price? If you'll give us a complete list of all the engine, and driveline specs I should be able to point you in the right direction. Technical Support, Barry Grant, Inc. www.barrygrant.com |
Originally Posted by GrandSportC3
(Post 1558758272)
great article!! Looks that I did well when selecting my carb..
They recommend it for durations over 220 degrees and mine is 270 degrees @.050 :lol: down legs. |
Originally Posted by Doug S
(Post 1558759075)
I'm sure you could have someone try to port it, but if not done properly it will ruin the carb. It's not something we offer.
If you'll give us a complete list of all the engine, and driveline specs I should be able to point you in the right direction. Technical Support, Barry Grant, Inc. www.barrygrant.com Driveline: McLeod Street Twin clutch, Tremec TKO-II 5 spd (3.27 1st gear) and 3.08s out back (may grow to 3.36s or 3.52s) |
Originally Posted by 69 N.O.X. RATT
(Post 1558759463)
Oliver, I'll bet with your set up your car would be faster with
down legs. |
On your combination we'd go with a 1000 Race Demon. It will give you better atomization for the fuel with your cam profile, and increased air flow without the choke tower and assembly.
Here's a link to a C-454 dual plane. It's not perfect...but it's the one I was talking about. It will fit a Dominator under an L-88 hood.
http://cgi.ebay.com/ebaymotors/EDELB...QQcmdZViewItem I use a 1050 Dominator with annulars on my 540. With my 3.07 gears they help keep throttle response crisp. I originally set it up to work on my 427...but it does Ok on the 540. I've done back to back dyno and strip tests with a Mega $$$$ modified 1400 cfm Dominator and a $1300 AED 1150. Neither made any more power or ran any faster. Well OK..the 1400 made 6 more HP at the peak..but was a slob under 5000 rpm. The AED was slower on my car. Until I change things to move more air..the 1050 is plenty. JIM |
(Post 1558760840)
(Post 1558788587)
Doug - I called your tech service dept to ask more questions about the 1000 and he asked about my engine/driveline. He asked if the 5th gear of the tranny was 1:1 or an OD and, finding it was OD, recommended the Race Demon RS 950 which is essentially a 1050 with annualer boosters since he says the cam will have a hard time with cruising in 5th at low RPM without them. He also said that with the removable sleeves, I could cater the carb size (flow in cfms) to what works the best. So what is your take on this?
(Post 1558760840)
Originally Posted by gkull
(Post 1558789283)
What would you recommend for my new 434 small block. 7500 rpm Brodix single plane will have Brodix 15 degree heads soon with 272 cc intake. 11.8 compression. Road racing Solid roller with 248/250 110 LSA .685/.715 lift. Very free flowing race exhaust with race mufflers.
(Post 1558789283)
