Follow along as I add a custom frame, LS2 engine & 5-speed to a '65 vette!
My project:
-Remove the '65 body off the original frame -clean/repair body -replace on a custome C2 Corvette frame with C4 suspension and change the engine to a 2006 Corvette LS2 with 400hp and a Tremec 5-speed transmission. I'll post updates every Friday night around 10pm. I expect this project to take about 2 months. Here are the before pictures. Colt:thumbs: http://i72.photobucket.com/albums/i1...PB260162-1.jpg http://i72.photobucket.com/albums/i1...2/PB260157.jpg |
Good luck...sounds like a great project...:thumbs:
Don't forget to post as many pics as you can...we always like pics. You should also maybe ask the moderators if you can post to a sticky or perhaps maybe have them make a sub-forum to the C1 & C2 Corvettes forum for projects being done by CF members...:cool: |
sweeeeet
:iagree:
You have my undivided attention! |
Originally Posted by 90ZR1
(Post 1558392893)
My project:
-Remove the '65 body off the original frame -clean/repair body -replace on a custome C2 Corvette frame with C4 suspension and change the engine to a 2006 Corvette LS2 with 400hp and a Tremec 5-speed transmission. I'll post updates every Friday night around 10pm. I expect this project to take about 2 months. Here are the before pictures. Colt:thumbs: Can we time you? :eek: |
After I took these photos, I washed and vacuumed the car.
I'm diving in, removing the body first. The frame is pretty rusty, but I already have 2 of the 6 main bolts off. Here are a couple more pics. http://i72.photobucket.com/albums/i1...2/PB260159.jpg http://i72.photobucket.com/albums/i1...2/PB260161.jpg |
Good luck, Colt. Any idea what the final numbers will be in engine, tranny, and frame????
Steve |
Keep us posted...:thumbs:
Originally Posted by mid-year crisis
(Post 1558395288)
Steve I'm getting a brand new Rock Valley gas tank with the electric pump and baffle (for cornering) already installed. This will be about $1000. I'm getting a new Griffin radiator and electric fan for about $1000. Total misc parts about $1000. So I expect to spend about $30,000 on this project total. So far, everything is right on track. |
[QUOTE=90ZR1;1558392893]My project:
-Remove the '65 body off the original frame -clean/repair body -replace on a custome C2 Corvette frame with C4 suspension and change the engine to a 2006 Corvette LS2 with 400hp and a Tremec 5-speed transmission. I'll post updates every Friday night around 10pm. I EXPECT THIS PROJECT TO TAKE ABOUT 2 MONTHS. Best of luck on this build. If you can stay on schedule and within budget, you should have you own TV show. The problem with these builds is the " I have gone this far, so why not just do a little more " syndrome. My red car started with a simple L-88 install and spiralled out of control to the tune of 12 years, 6000 man hours, $96000. in parts ( includes paint work , done by others ) and I did all the work myself, except the paint. WE will be watching. Good luck again. vetrod62 |
Originally Posted by vetrod62
(Post 1558398957)
My red car started with a simple L-88 install and spiralled out of control to the tune of 12 years, 6000 man hours, $96000...
Originally Posted by ratpack1968
(Post 1558399315)
...and it shows. Just checked out your pictures and your car is awesome. Nice work. :thumbs:
Pics...how 'bout a webcam :D
:cool: :thumbs: |
Welcome to this week's update. Well, the left rear body mount plate came off when I removed the bolt. Both rear caged nuts spun, so I had to get in the back of the car and remove the left side vent fan and pull up the carpet and got some vice grips on both rear nuts. The left rear still wouldn't budge. A saw-zaw did the trick. :thumbs: All the others came out OK. removed the steering linkage, radiator support bolts, tach drive, e-brake cable, all the bumper brackets, 4 seat-belt bolts, tranny cable, splash guards in front, oil press and water sending units, Z-bar, etc. I lifted the car using my car lift with 8 tie-down straps (each has a max of 400lbs).
The old chassis has sold and is being picked up this w/e. In the coming week, I'll start detailing the engine bay and will get a bucket of soap water and rag and scrub the under-body. http://i72.photobucket.com/albums/i1...2/PC150028.jpg http://i72.photobucket.com/albums/i1...2/PC150022.jpg http://i72.photobucket.com/albums/i1...2/PC150023.jpg http://i72.photobucket.com/albums/i1...2/PC150026.jpg I'm doing a DVD of this project as well. Will try to post some pics of the new parts as they arrive. No major snags yet (knock-on-wood)! |
Originally Posted by bluestreak63
(Post 1558393207)
Colt |
On the main page of C1 & C2: at the bottom of the page MasterDave is th Mod of this section. Just PM him. :thumbs:
http://forums.corvetteforum.com/member.php?u=1526 |
Industrious project. 2 months with parts in hand is doable. waiting for vendors to ship you the ordered parts may impact your schedule some what. Best of luck and thanks for the pics. :thumbs:
Russ |
Originally Posted by Russ T Gate
(Post 1558498364)
Russ Regards, John McGraw |
Local guy here did the same thing about a 2 years ago.. The car was absolutely awesome.... He just recently moved to Florida... He also had the new flared rear wheel wells on it.. It was sweet.. I look forward to seeing your progess..
/joe |
(Post 1558398038)
Big ones. The engine is about $6000, the tranny $4,200, the frame about $15,000 decked out with all C4 suspension, rack and pinion, the big Dana 44 rear and painted 1996 vette calipers. This tremed setup comes with new flywheel and driveshaft too. The harness and computer run about $2000.
