Factory Cam Specs List- Small Block
Chevrolet Factory Cam Specs with GM part numbers
Part # Lifter..duration @ .050 In/ex--Lift in/ex....centerline.....factory eng. 3849346 Mech - 254/254 - .484/.484 - 114 - 327 365HP& Z-28 302 3863151 Hyd. - 221/221--.447/.447-114 - 327-350HP, L79 3896929 Hyd. - 195/202 - .390/.410 - 112 - 327 300 HP 3896962 Hyd. - 222/222 - .450/.460 - 114 - 350 L-46, L-82 3927140 Mech - 257/269 - .493/.512 - 112 - Off Road 3965754 Mech - 262/273 - .488/.509 - 112 - 2nd design road race, short track 3972178 ? 3972182 Mech - 242/254 - .459/.485 - 116 - 70 LT1 360 & 370HP, 71 LT 330 HP 10134334 Roller - 235/235 - .480/.480 - 114 - 350ZZZ and ZZ2 Crate Motor 10185071 Roller - 208/221 - .474/.474 - 112 - 350 345, ZZ3&4 Crate Motor 10224241 Roller - - 92-94 GenII, LT1, 350 10243779 Roller - - 94-96 Gen II, L99 265 V-8 12353914 Hyd. - 180/194 - .378/.401 - - GM Crane Lo speed Hi torque 12353915 Hyd. - 194/204 - .401/.423 - 104 - GM Crane street 12353916 Hyd. - 204/214 - .423/.446 - 110 - GM Crane 305-350 street legal 50 states 12353917 Hyd. - 204/214 - .420/.441 - 112 - GM Crane nan-emissions vehicles & off road 12353918 Hyd. - 214/224 - .442/.465 - 112 - GM Crane marine & off road 12353923 Hyd. - 224/234 - .465/.448 - 114 - GM Crane off road 12364050 ? 12364051 ? 12364052 ? 12364053 ? 12364054 ? 12370845 Roller - 214/224 - .488/.509 - 112 - Off Road, lobe for mech fuel pump 12370846 Roller - 222/230 - .509/.528 - 112 - Off Road, lobe for mech fuel pump 12370847 Roller - 232/242 - .539/.558 - 112 - Off Road, lobe for mech fuel pump 12551142 Roller - 203/210 - .476/.480 - 115.5 - 96 350 LT4 w1.6 roller rockers 12551705 Roller - 201/208 - .447/.459 - 112 - 95-96 Gen II, LT1, w center dowel pin 14088843 Hyd. - 202/206 - .403/.415 - 115 - 305 HO, 83-86 14093643 Roller - 202/206 - .403/.415 - 115 - 87 350 Corvette, IROC Camaro 24502476 Hyd. - 121/220 - .435/.460 - 112.5 - 350 300 crate motor 24502586 Roller - 218/228 - .525/.525 - - 96 LT4 H.O.T. crate motor, use with 1.6 roller rockers NA........ Roller - 202/210 - .472/.478 - 111 - 97 Gen III LS1 Corvette 350 uses 1.7 roller rockers |
If you have others... or would like to post Big Block specs.. Have at it-
Can you find the actual timing (the equivalent of a cam card)?
Intake and Exhaust timing at 0.050" lift (and 0.006" and 0.015" lift to compare with other cam grinders & the "blueprint" grinders)? Intake and Exhaust timing at lash point (for Mechanical cams)? Intake and exhaust POML? Intake closing point BTDC? Finding this information may prove challenging, and rewarding (blueprints and full specifications for some GM cams are out there, but I have never found found them on the net). Thanks :) |
I don't have those details, Ed... some of the cam makers have details
like those on their websites... but I wouldn't know where to get those facts on GM Factory cams. I suppose if one of the cam makers was making a true reproduction part you might be able to exume that info from them .... but, there might still be a tad of difference between their reproduction and the factory cams. One of our more GM savy members might know... |
** Remember, you can alter the total lift of these cams by changing
the ratio of your rocker arms... the factory rocker arms are 1.5 ratio arms. Changing to 1.6 or 1.7 ratio arms will provide you with more lift. To see how much more lift.... divide the cam's lift by 1.5... then multiply that answer by (1.6 or 1.7) (the new ratio) to obtain the new total lift numbers. This rocker modification, for example, would allow you to run the duration of a L-82 cam.... with the lift of a Duntov....lots of options. It is also something you could do if you wanted a little more power from a hydraulic cam without having to step up to a solid lifter cam and perform the adjustments that come with running a solid lifter cam. Check with your machinist to prevent any clearance or rubbing issues... also check and make sure you don't need new pushrod lengths with the altered rockers. |
Originally Posted by KyleDallas
(Post 1558292524)
the ratio of your rocker arms... the factory rocker arms are 1.5 ratio arms. Changing to 1.6 or 1.7 ratio arms will provide you with more lift. To see how much more lift.... divide the cam's lift by 1.5... then multiply that answer by (1.6 or 1.7) (the new ratio) to obtain the new total lift numbers. This rocker modification, for example, would allow you to run the duration of a L-82 cam.... with the lift of a Duntov....lots of options. It is also something you could do if you wanted a little more power from a hydraulic cam without having to step up to a solid lifter cam and perform the adjustments that come with running a solid lifter cam. Check with your machinist to prevent any clearance or rubbing issues... also check and make sure you don't need new pushrod lengths with the altered rockers. I saw some roller tiped rockers that Ecklers sells, but they only have a 1.52 ratio. They claim another 10 HP or so. I saw some 1.6 on Comp cams website and they claim 15-30 HP increase. Anyone have any actual experience with these and can say these claims are true? Also, will these rockers (1.52 or 1.6) fit under the stock SHP small block valve covers? (Alum Finned ones) |
Originally Posted by Dicecal
(Post 1558294517)
(Post 1558294517)
2 Attachment(s)
Originally Posted by Kensmith
(Post 1558294764)
Most if not all roller rocker arms need the tall valve covers. :thumbs:
The Comp Cams Roller tip, Magnum and Pro Magnums have no problem clearing under stock finned valve covers. I've had all of them on my motor and have yet to have a problem. I've used the thick valve cover gaskets just for the extra clearance but it was not needed. :thumbs: Dave Attachment 48173055 Then I believe this is a pic of 65TRush's set up under stock covers Attachment 48173056 |
Originally Posted by youwish2bme
(Post 1558295078)
Dave http://img.photobucket.com/albums/v1...gtheintake.jpg Then I believe this is a pic of 65TRush's set up under stock covers http://img.photobucket.com/albums/v1..._0212_2_31.jpg |
http://www.ecklers.com/product.asp?p...dept%5Fid=1211
These are the rockers I was refering to, steel roller tipped rockers comp cam magnums. They do not have the tall studs, just nuts like stock rockers. |
AFR and Dart heads have raised rails. In other words where the valve cover bolts on they are .5 higher than stock GM heads. Thats why roller rockers will fit under stock valve covers when using aftermarket heads. Most will not clear with stock heads. Sometimes double gaskets work or just buy spacers.
(Post 1558300696)
These are the rockers I was refering to, steel roller tipped rockers comp cam magnums. They do not have the tall studs, just nuts like stock rockers. I can't verify or deny the HP gain from the roller tip rockers but I have a set of the Comp Cam units on the 427 in the vette and on a 327 in my 32. I put them in just to ease up the wear as much as possible on the valve train. They do fit under the stock valve covers. I had stock covers on both engines when I put them in. Steve |
Originally Posted by 66BlkBB
(Post 1558304280)
Either HOT ROD or CAR CRAFT had an article on a series of back-to-back dyno tests about a year or so ago on the same engine with four different cams and combinations of 1.5 and 1.6 ratio rockers to answer that perennial question, and their conclusion after all the testing was done was that changing from 1.5 to 1.6 rockers wasn't worth the money and effort in real-world driving. :thumbs:
Originally Posted by JohnZ
(Post 1558306495)
It is not the roller rockers but the nuts that have clearance issues. :willy:
Yes you can make them fit. :D Shaft rockers are better. :thumbs: |
The increase in power that results from increased lift.... caused by
either a cam swap or a rocker arm change will be partially determined by how well your heads flow at certain lifts....... this is why I ranted a few weeks back on how great the Dart Iron Eagle Platinum heads were. Unlike the old days when you just kind of guessed at a heads performance.... today, most of the aftermarket head manufacturers list their head flow in cfm at various lifts... usually between .200 lift to .700 lift ..... most of the street cams for the SBC have a lift in the .400 lift range as you can see above.... I would agree with John on the limited benefits of increased lift on heads like the Double Humps.... but on Heads like AFR Eliminators, Dart Iron Eagle Platinums, GM Performance Parts Vortec Bowties, GM Performance Parts Fast Burns, Trick Flows, Canfields, Stock L-31 Vortecs, RHS Vortecs, and any of the altered angle 18 degree-etc. heads available..... lift equals a good return on your investment of a new cam or rockers that put your lift into the heads "flow sweet spot". I will make a statement that may make some a little miffed... but there isn't anyone today,who is serious about performance,that doesn't look at the lift vs. flow data of the heads they are using..... If you don't know what your heads flow at certain lifts then how can you even remotely gauge the performance potential of the motor you are trying to build??..... you can't.... and if you are using old heads that flow the same baisic cfm at .400 and .500... then, yes, there's not too much to be gained by extra lift. ...... the main reason some 350's struggle to make 400 hp and others easily top 500hp is headflow and lift.... via cam and/or rocker ratio. For example... let's look at the headflow on the old 64cc chamber Chevy '492 casting with 2.02/1.60 valves.. vs. some of the heads I've mentioned. Notice the 492 casting flow cfm in the .400 to .500 range..which is where alot of the SBC GM cams above put lift.. (.410 to .480 lift) .8 cfm difference from .400 lift to .500 lift...and only 11cfm difference in flow between .400 and .600 lift.... with the 492's the extra lift is pretty much wasted. HEAD.................Portsize..lift/cfm@ .300.......400.......500.......600.... GM492/2.02..........157/62...........173/125..198/137..206/141..209/141 ------------------------------------------------------------------- L31 Vortec #885....170/61...........190/129..227/140..239/147..229/151 --------------------------------------------------------------------- AFR Comp190's......190/xx...........201/157..243/180..264/195..276/208 -------------------------------------------------------------------- Dart Platinum IE....200/xx............194/158..242/198..274/208..283/214 -------------------------------------------------------------------- Bowtie Vtec185....185/xx.............182/xx...223/xx....251/xx....240/xx Look at the Dart Iron Eagle Platinum 200cc port heads..they start off flowing 44cfm more at .400 lift than the '492s and you gain 33cfm more if you increase lift to .600. If these lift numbers scare you because you are used to SBC lift numbers.... do a little cross-training and go look at the lift numbers the LS engine guys are running in their aftermarket cams... .500 to .650.. you just have to have a valvetrain built to handle it. The general rule of thumb is to look at the lift numbers of your cams peak lift...and the lift numbers of the group just below (where your cam will place your lift while it is off the seat the majority of the time) So if you had a .510 total lift cam... you would look at the heads flow at .400 lift and .500 lift to get a rough idea of what your heads will be flowing a majority of the time. Notice on the L31 Vortec heads and the Bowtie Vortec 185cc's how flow drops down at .600.... but on the AFR Comp 190's and Dart Platinum 200's it keeps climbing. Something to consider when deciding on a cam.... or revising lift with different rockers. Here's what a 520hp 350 looks like: http://airflowresearch.com/articles/article054/A-P1.htm the 520hp engine has.... 1. Good flow number heads 2. A cam that takes advantage of that flow 3. A good Demon carburetor and spacer 4. A good Edelbrock intake.. I believe you could replicate that motor using your stock block and have about 170 more horsepower than a ZZ4 for about the same money.:thumbs: |
1 Attachment(s)
(Post 1558294517)
Unless you are going to go well over .500 lift.. I wouldn't worry about fancy rockers... just get'em in your desired ratio.... roller tips are a good compromise between a stock and a full roller rocker.... for about $100 give or take.... These PRW rockers are good quality and are similar to the Comp Pro Magnums... but cost $100 plus less... Attachment 48173046 CNC Motorsports has them for about $180.00 here is PRW's website..... http://www.performanceracingwarehous...p-rockers.html PRW has some nice roller tipped rockers also Scorpion Performance makes rockers in the 1.7 ratio... A Rocker ratio change is also a way to cheat the cost of going to a roller cam and still getting into the .500 to .550 lift range with a plain hydraulic cam with streetable duration. |
Here is a practical application for the use of different rockers on
a 327/350hp L-79. You are surfing Ebay and notice a set of Vortec L31 #885 heads with a Buy it Now price of $300.00 complete with valves, rockers, etc. ..... You buy the heads and order a set of 1.7 ratio rockers... you leave your L-79 cam intact... but instead of giving you .447/.447 lift... you are now getting .506/.506 lift... making the most of your head flow while not digging into the block. L31's go for $300 to $350 a pair pretty routinely. If you wanted to step up a little over the L31's... you could order the 185cc Bowtie Vortecs for $554 a pair bare from GM Performance Parts Direct.... or the Dart IE Platinums 200cc port for $660.00 a pair bare from Competition Products.... and use the same rocker ratio trick with your stock L-79 cam. Intake flow for 492's with stock 1.5's 198cfm at .400 lift Intake for L31's with 1.7 rockers 239cfm at .500 lift Intake for Bowite Vortec 185cc with 1.7's 251cfm at .500 lift Intake for Dart IE Platinum 200cc with 1.7's 274cfm at .500 lift all figures using the stock L-79 cam... |
