Here are some shots of mine as I was doing my bodyoff.
http://members.cox.net/vettenut72/c3forum/front1.jpg http://members.cox.net/vettenut72/front2.jpg http://members.cox.net/vettenut72/c3forum/rear1.jpg http://members.cox.net/vettenut72/c3forum/fuel2.jpg http://members.cox.net/vettenut72/c3forum/rear2.jpg Craig |
Very nice job !
I got to work on mine last night. I painted the front calipers red using Duplicolor Caliper Paint. It was easy and a nice shade of red. I put 2 coats on right after each other and have let them dry now for 12 hours. After inspection, I can see some translucent areas, so I am considering another coat - will see..... They look good tho! VetteNut and Bangcok - what type paint did ya'll use? What about your spare tire carrier - looks like gloss? what type? any specs on how long ago and the durability of your paint selections? |
Right here
| | \/ http://forums.corvetteforum.com/show....php?t=1107000 and here | | \/ http://photobucket.com/albums/v613/kortensi/ |
2 coats por-15 on frame then gm chassis black top coat,, all stainless lines- gas-- brake-- and braded stainless to cailpers--inner rails of frame had 2 coats of z-bart rust proofing,,spindles por-15 metal mask and entire steering components then a clear coat of glisten p.c. rock hard clear coat,,any exposed metal was treated with por-15 metal mask and glisten p.c clear coat,,,,chambered exhausts and manifolds are ceramic jet coated,,1/2 shafts are chrome plated,,safety loops are ''FORD RED'' shocks are body shop blue,,frt springs black power coated rear spring is monoleaf,,,tire tub is 3 coats black 3 coats clear and the ''y'' strap was ceramic jet coated and re-swedged using correct factory rivits on a anvil and swedging tool ect ..ect..ect on and on and onhttp://www.imagesup.com/usr/90/100_0669.JPG
this is a photo before i had the 1/2 shafts chromed,,,matter of fact i still have these , i bought another set and rechromed them,,,these are por-15 metal mask and glisten p.c. clear coathttp://www.imagesup.com/usr/90/4364100_0388.JPG
