The inside of a catalytic converter....
looks like what? Mine looks hollow and wide-open. Did the previous owner open it up? Anyone...what should it look like as you look through it?
Thanks. |
thats a good ?, i have never seen one either
Inside of a Cat Converter
It looks like a light collimator or a fine honeycomb. You can see straight through it but not at even a slight angle. The grid is usually a few inches thick (in the direction of flow) and the grid has small openings - less than 1/16". If the grid is lying around in pieces, it has fractured and will give poor performance (pollution-wise and high rev.-wise)
Sounds like yours has been gutted. |
:iagree:
Best pic I could find with a quick search: http://www.schoolscience.co.uk/conte...ges/catcon.jpg |
There are multiple designs for cats, but I can guarantee that one of them is NOT an empty tube. Just think... free HP!
'85 cat has this fine honeycomb type material from one end to the other
http://i21.photobucket.com/albums/b2...icture1165.jpg |
http://i21.photobucket.com/albums/b2...icture1165.jpg I have no emmission testing here so I guess this is a good free mod! |
Will a gutted cat converter cause any damage to the engine?
Sounds like your cat was "rodded out".
excellent pic of the cat!
nothing a crowbar can't fix ;) Too bad its so toxic, there is a lot of Platinum in there. |
Thanks. |
Originally Posted by 86PACER
Someone gutted it. It should look like the photo posted.
