Innova #5568 timing light How to use
Hello, I just bought a innova 5568 and i am not really sure how the timing works on it. The manual is a bit confusing. I have only used my old cheap timing light before this. I am trying to time my 350 camaro to get a feel for this light. Then i will do the dwell and timing on the corvette. Thanks Eric
If it is anything like a dial back timing light you adjust the light to what ever deg adv you want and then adj the dist until the balancer reads 0.
Hello, This EQUUS/INNOVA 5568 pro timing light i believe is a dial back timing light. Thankyou for your input i will try it.
Thanks Eric |
Thanks Eric The trick is getting familiar with the various little ICONS on the screen. It can be confusing! You need to 1) understand the manual 2) PLAY with it - press the various buttons and watch the icons change. Once you get used to the user interface, you will love it! I have had mine for a couple of years and I find that, because I don't use it often, I have to review things for a bit before I get down to business. |
:withstupid:
I dropped and broke my 30 year old timing light. Bought a Innova 5568 and the instruction manual is not that great. Frustrating. Still playing with it all day trying to figure it out. :willy: |
And it doesn't work with my MSD 8572 + 6AL box :-((
Originally Posted by c3_dk
(Post 1574826105)
What behavior have you seen using it with the 6AL? |
I have this timing gun and have been wanting to check and adjust the timing on my Camaro, but haven't gotten to do so. It's still brand new. I need to get to doing this ASAP to try it out.
