FOR SALE: Kwiklift
SOLD!!!!!!!!!!
1 year old Kwiklift for sale. In excellent condition. Will not ship but will assist in delivery by meeting halfway up to 150 miles. This should cover Ohio, and most of Michigan, Indiana, northern Kentucky. Lift comes with 2 center bridges and oil change container. Asking $1250. Price new is almost $1700. http://i83.photobucket.com/albums/j3...1/DSC00142.jpg http://i83.photobucket.com/albums/j3...1/DSC00141.jpg |
I may be interested. What color are they? What is the lift height? I'm in Youngstown, where is Lima? What is the overall length? What lifts the back end up?
Lima is halfway between Toledo and Dayton off of I-75 |
Originally Posted by Norm_05_ GTO
Will you deliver to Rochester? Approx 30 miles north of Detroit. How hard is it to set up? How long would it take? Is the price negotiable? Very interested.
kwik lift
I have this unit and am confused about the lift hight measurement mine measures 20" in the raised position. Your not measuring with your private parts are you:toetap:
My guess is that his lift height is the measurement from the floor to the bottom of the rockers...
ttt
ttt
ttt
I am going to buy, but I do have a question....if you have a racedeck floor, is this usuable? Or would it be better to have a concrete slab? I ask because of the lifting.
kwiklift
I have mine on a vinyl tile floor and it would slip forward untill i put rubber mats under the front legs and rear rails. If your floor has better grip you should'nt have any problem. try not to use the brakes when driving on and it won't move even on a smooth floor. My Vette is lowered and it goes on without A problem. If like me you have a low ceiling this is the way to go. You can park on it without raising it up and not lose a parking space. I love mine
Check out the lb rating from Race Deck. The Kwik Lift is an awesome tool and great for the $$$. Good luck! Steve |
Would you take $1000?
Also, what is the width of it at its widest and the length at it's longest? |
The footprint on it is fairly small and I think it would distort the racedeck as it does when you use a jack:cheers: |
Originally Posted by Mickbee
Not 100% sure about race deck. However, I had mine installed on Moto-Mat and it worked perfectly. Same with a 4-post lift.
Check out the lb rating from Race Deck. The Kwik Lift is an awesome tool and great for the $$$. Good luck! Steve I currently have it setup in my garage and just cut a few squares of carpeting to place underneath it when I use it as a lift just in case. I also have racedeck installed. I asked Racedeck before setting it up and they told me it would be fine. If a tile SHOULD get damaged, they currently have a 15 year warranty so no worries. :cheers: |
