Originally Posted by neat
Just curious, why are so opposed to nitrous? There is nothing in your price range that can compete with the bottle.
My list above will likely give him around 100 more rwhp all the time without reocurring bottle costs. I'm not against Nitrous at all, it is awesome, I am just stating why other options sometimes outweigh it. :) |
Originally Posted by scorp508
On a stock L98 you don't want to go over a 100 shot due to the cast style pistons. To do it right with all the safety equipment (fuel pressure cutoff, RPM window, ignition that can retard timing) you'll most likely spend over $1000, and thats before the bottle is filled. I know, I've got a full NX kit on my car (Well I did, I have since removed it).
My list above will likely give him around 100 more rwhp all the time without reocurring bottle costs. I'm not against Nitrous at all, it is awesome, I am just stating why other options sometimes outweigh it. :) -- Joe |
Originally Posted by anesthes
The links on your website are broken. Do you have any more large pix of your car? I dig the color.
-- Joe *edit* Here ya go, I uploaded a couple of 1600x1200 shots for ya. In direct sunlight the yellow is duller compared to say the later Competition Yellow. On overcast days it looks extremely yellow. http://home.comcast.net/~scorp508/bigcar1.JPG http://home.comcast.net/~scorp508/bigcar2.JPG |
I'm in the middle of taking that page down to move to a new webhost. lemme upload something...
*edit* Here ya go, I uploaded a couple of 1600x1200 shots for ya. In direct sunlight the yellow is duller compared to say the later Competition Yellow. On overcast days it looks extremely yellow. http://home.comcast.net/~scorp508/bigcar1.JPG http://home.comcast.net/~scorp508/bigcar2.JPG Mine is fugly gray. Trying to decide what color to paint it... http://members.cisdi.com/~anesthes/p...wimg/back1.JPG http://members.cisdi.com/~anesthes/p...wimg/side2.JPG -- Joe |
My list above will likely give him around 100 more rwhp all the time without reocurring bottle costs. I'm not against Nitrous at all, it is awesome, I am just stating why other options sometimes outweigh it. :) If he doens't want to use nitrous no problem. I just want to be sure his isn't dismissing nitrous because of all the rumors and incorrect information you see in the movies, read on the net, and hear on the street. Nitrous is a fairly cheap, reliable, and extemely viable way to make power. Dismissing it because you've heard some rumor somewhere that it is dangerous, blows up engines, is extra hard on parts, or some other street myth about nitrous is kinda dumb in my opinion. |
I'm going to have to respectfully disagree. Lot's of people take them to 150 routinely with no failures. Skateparkdave has been using a 125 shot for over 2 years and my 91 has seen 140 numerous times with no ill effects. If the proper safety parameters are in place, I don't see why 400 RWHP would destroy a cast piston.
-- Joe |
I haven't seen many 113 headed cars making 350 RWHP, but it's possible I guess. The flip side the the power all the time is that you are putting that wear and tear on the engine and drive train all the time. With nitrous, he can go out and throttle his stock L98 all night long, and only put the stock amount of wear on the engine, trasmission, rear end, basically the entire car. Then, when the time is right, open the bottle and really lay the smack down. He can do all that, and only spend a day in the garage instead of the weeks the car will be down doing the heads and cam swap. Nitrous is a fairly cheap, reliable, and extemely viable way to make power. Dismissing it because you've heard some rumor somewhere that it is dangerous, blows up engines, is extra hard on parts, or some other street myth about nitrous is kinda dumb in my opinion. |
:eek: ,,,,:lurk:
Does the car smoke when decelerating? you said it smoked upon start up. If your cruizing along at a good pace, and take your foot off the pedal, and maybe gear down, if you see alot of smoke. Usually you are looking at valve guides. A lead down test can tell you alot. Apply the air, and listen at the opening of the throttle body, if you hear air escaping "intake valves". Put your ear to the exaust if you hear air escaping "exhaust valve". put your ear to the oil filler hole cap off, if you hear air escaping "piston rings, or possibley valve guides" I hope this helps. Nothing is for sure, but it gives you a good idea... Perhaps a compression test might be in order... :thumbs:
Fair enough, I'm glad its worked for those cases. It isn't the RWHP that kills the cast pistons, it is the cylinder pressures spikes caused by the nitrous injection that kills them. FWIW the '85 has forged units so it isn't an issue.
If you can explain why 400 RWHP NA is easier on an engine that 400 RWHP with N20, PM me. If the cylinder pressure is greater with the nitrous than NA, then the engine would make more power. There is a cylinder pressure spike on initial engagement with nitrous, but it should only spike to pressure required to make the HP associated with the shot. If the spike was outrageous, you would see an appropriate increase in RWHP on initial engagement. I agree that nitrous can break a cast piston, but I don't think it's possible on an L98 assuming no detonation and less than 400 RWHP. And I've never seen a stock L98 make 250 RWHP, so 350 wouldn't be the number to use. :) For a while at least, hopefully he doesn't run into a lot of races or do high MPH pulls like I like to do. :) Weeks? Find a new mechanic! Heads and cam can be done in a day if you've got all the parts lined up and know what to do. It isn't rocket science thankfully. Both setups will require dyno tuning (more likely more for the head/cam route). I don't disagree with you. Like I said, I like Nitrous and had a full NX EFI 50-150 wet kit installed on my car along with all the other stuff. I like nitrous, I think it's a great power adder. I try pretty hard not to let my personal opinions enter into me giving advice though. Like I keep saying, I just want him to have the information, then make up his own mind. Instead it's turned into 2 guys trying to figure out what someone else should do. Why not just offer advice and let him make up his own mind? If you're close to NC, we can meet at a track and settle the heads/cam VS nitrous debate. Your H/C car against my nitrous car. EDIT: It looks like your in MA. I might be able to make up to the DC area sometime this summer, I'd be glad to meet you at a local track. Let me know if you are game. |
Mine made 251/341 with just headers and a catback. 1991 L98 with a ZF6. I guess 330 RWHP would of been a better number for you, but we're really splitting hairs. Not many 113 headed cars make 330 either. My point is that it's not for either one of us to decide for him. All I wanted to know was why he had chosen not to use nitrous. Now, we're going back and forth on whether or not it's the right thing for him to do. I just want him to have the information, and then he can make up his own mind. If he does the heads and cam himself, in the garage, and it's his first time; it's going to take him a minimum of 10 evenings and two 10 hour days. Can we at least agree that nitrous is easier to install than heads and cam? It sure sounds like you don't agree with me, lol. Why not just offer advice and let him make up his own mind? If you're close to NC, we can meet at a track and settle the heads/cam VS nitrous debate. Your H/C car against my nitrous car. EDIT: It looks like your in MA. I might be able to make up to the DC area sometime this summer, I'd be glad to meet you at a local track. Let me know if you are game. |
