1990 vette harness
hey guys i pulled out my old bose system from my 1990 and i was wondering what harness i need to plug in my aftermarket pionner into.
The bose hookups in the car seem to have 2 separate prongs. The 88and up GM wiring harness doesn't seem like it fits. Where can i buy the wiring harness? any links? thanks. it wasn't too clear in the faq. |
Aftermarket Installation
Assuming you want to use the existing Bose speakers and amp and just replacie the head unit, you need a special amp intergration adapter. It's available from www.crutchfield.com and other vendors.
If you're going with all new equipment, you're going to need to bypass the stock Bose amp, which I think is located in the passenger side das. The harness you need is actually plugged into the stock amp. Read the C4 Stereo Sticky for all the details. |
