1972 VIN Codes (Part of a series)
Please Note – this is NOT going to be 100% accurate. Numbers changed, I coulda mis-typed, but this is the best I can do as a back yard mechanic to help you out. This came from 3 different books, and I tried to put all 3 into one page for ya. Please look for the book CORVETTE BY THE NUMBERS for more accurate information. Thanks.
1972 Corvette DECODING THE VEHICLE IDENTIFICATION NUMBER For the first time, Engine codes were in the VIN VIN # is stamped on the inside of the A pillar windshield. Convertible Vin #’s were 1Z67K2S500001 TO 1Z67K2S527004 Coupe Vin #’s were 1Z37K2S500001 TO 1Z37K2S527004 Symbols, Letters and their meaning: 1st Chevrolet 2nd Z for Corvette 3RD and 4th = 67 Convertible, 37 Coupe 5th Engine K = Base 350 W = LS5 454 6th Symbol indicates Year (2 = 1972) 7th Symbol indicates Assembly Plant (S = St Louis) The last six symbols are the production numbers. 1968 – 1978 Corvette Trim Tag ID Upper right corner is body build date A = August 1971 B = September 1971 C = October 1971 D = November 1971 E = December 1971 F = January 1972 G = February 1972 H = March 1972 I = April 1972 J = May 1972 K = June 1972 L = July 1972 The Second and Third numbers were the day of the month that production of this car started. On the left side is a word TRIM followed by the following: 400 = Black 407 = Red 412 = Blue 417 = Saddle 404 = Black Leather 421 = Saddle Leather Just right of that is the word PAINT followed by the following: 912 = Sunflower Yellow 924 = Pewter Silver 972 = Classic White 945 = Bryar Blue 946 = Elkhardt Green 973 = Mille Miglia Red 979 = Targa Blue 987 = Ontario Orange 988 = Steel Cities Gray 989 = War Bonnet Yellow ENGINE CODES 1972’s consist of 8 characters: 1st is Assembly Plant 2nd and 3rd are Assembly Month 4th and 5th are Assembly Day 6th is C for Chevrolet 7th & 8th are the Engine Code Suffix Assembly Plants (Some engines produced at some plants were used in other cars.) F = Flint Motor Facility (No Corvette Engine this year from this plant) K = McKinnon Industries (No Corvette Engines this year from this plant) S = Saginaw Service (No Corvette Engines this year from this plant) T = Tonawanda V = Flint Engine Plant High Performance Code, Engine Size, Horsepower, Transmissions and Options CDH 350, 200, 4 Speed Rochester 4 Bbl CDJ 350, 200, THM400, Rochester 4 Bbl CKW 350, 200, 4 Speed, Rochester 4 Bbl CKX 350, 200, THM400, Rochester 4 Bbl CKY 350, 255, 4 Speed, Mechaznical Lifters, Holley 4 Bbl CKZ 350, 255, M22 4 Speed, ZR1 Performance Package, LT1 Engine CRT 350, 255, 4 Speed, Mechanical Lifters, Holley 4 Bbl, AIR Injection CPH 454, 270, 4 Speed, Rochester 4 Bbl, Hyd Lifters CPJ 454, 270, THM400, Rochester 4 Bbl, Hyd Lifters CSR 454, 270, 4 Speed, Rochester 4 Bbl, Hyd Lifters, AIR Injection CSS 454, 270, THM400, Rochester 4 Bbl, Hyd Lifters, AIR Injection Corvette Engine Blocks (You may have a different block, if so it might be from another Chevy Vehicle) 3970010 350, 300, 350 & 370 HP, 4 bolt main (This block was used thru 1979 year) 3999289 454, 270HP, 2 bolt main Cylinder Head 3998993 350ci, 175HP, 1.94 intake 1.5 exhaust 75.47 cc 3998916 350ci, 255HP, 2.02 intake 1.60 exhaust 76.18 cc 3973487 350ci, 175HP, 1.94 intake 1.5 exhaust 75.47cc 3973487 350ci, 330HP, 2.02 intake 1.60 exhaust 75.47 3973487X – 350 Engine used in late 72. 3993820 454ci, 365HP, 2.06 intake 1.72 exhaust 113.060 3999241 454ci, 270HP, 2.06 intake 1.72 exhaust, 113 cc |
Tnx
:thumbs:
Thanks from another 72 owner. I have most of these, but sure I'm missing something...
So if my engine code has CKY in it then it is a CKY 350, 255hp, 4 Speed, Mechanical Lifters, Holley 4 Bbl without AIR Injection? Smog pump is no where to be found and I have always been told that all 72's had the pump from the factory.
much, but not all of that info available here:
http://www.rowleycorvette.com/stats72.html and here.. http://www.idavette.net/facts/72.htm |
