1968 VIN Codes (part of a series)
Please Note – this is NOT going to be 100% accurate. Numbers changed, I coulda mis-typed, but this is the best I can do as a back yard mechanic to help you out. This came from 3 different books, and I tried to put all 3 into one page for ya. Please look for the book CORVETTE BY THE NUMBERS for more accurate information. Thanks.
1968 Corvette Basics: Base Engine L75 327 V8, 300 HP 10.25:1 Optional Engines L79 327 V8, 350 HP 11.0:1, 5 main bearings, Hyd Lifters, HP Cam L36 427 390 HP L71 / L89 427 V8, 435 HP, 11.0:1, Alum Heads, 3 Holley 2 Barrel Carbs L88 427 V8, 560 HP, 12.5:1, Ultra Hi-Performance Cam DECODING THE VEHICLE IDENTIFICATION NUMBER VIN # is stamped on the inside of the A pillar windshield. Convertible Vin #’s were 194678S100001 TO 194678S128566 Coupe Vin #’s were 194378S100001 TO 194378S128566 Symbols, Letters and their meaning: 1st Chevrolet 2nd and 3rd Body Series (94 = Corvette) 4th and 5th Body Style (67 = Convertible, 37 = Coupe 6th Symbol indicates Year (8 = 1968) 7th Symbol indicates Assembly Plant (S = St Louis) The last six symbols are the production numbers. 1968 – 1978 Corvette Trim Tag ID Upper right corner is body build date A = Aug 1967 B = Sept 1967 C = October 1967 D = November 1967 E = December 1967 F = January 1968 G = February 1968 H = march 1968 I = April 1968 J = May 1968 K = June 1968 L = July 1968 M = August 1968 The Second and Third numbers were the day of the month that production of this car started. On the left side is a word TRIM followed by the following: STD = Black 407 = Red 411 = Blue 414 = Bright Blue 425 = Orange 435 = Tobacco Brown 442 = Gunmetal Gray 402 = Black Leather 408 = Red Leather 415 = Blue Leather 426 = Orange Leather 436 = Tobacco Leather. Just right of that is the word PAINT followed by the following: 900 = Tuxedo Black 972 = Polar White 974 = Rally Red 976 = LeMans Blue 978 = International Blue 983 = British Green 984 = Safari Yellow 986 = Silverstone Silver 988 = Cordovan Maroon 992 = Corvette Bronze ENGINE CODES 1968 and 1969 consist of 7 characters: 1st is Assembly Plant 2nd and 3rd are Assembly Month 4th and 5th are Engine Code Suffix Assembly Plants (Some engines produced at some plants were used in other cars.) F = Flint Motor Facility (No Corvette Engine this year from this plant) K = McKinnon Industries (No Corvette Engines this year from this plant) S = Saginaw Service (No Corvette Engines this year from this plant) T = Tonawanda V = Flint Engine Plant High Performance Engine Code Suffix ID’s Code, Cubic Inches, HP, Transmission and Options HE, 327, 300, Man Trans, Rochester 4 Bbl HO, 327, 300 THM400 Auto, Rochester 4 Bbl HP, 327, 350, Man Trans, Rochester 4 Bbl, A/C, P/S HT, 327, 350, 4 Speed Man, Rochester 4 Bbl, Special Cam IL, 427, 390, 4 Speed Man, Rochester 4 Bbl, Hyd Lifters IQ, 427, 390, THM400 Auto, Rochester 4 Bbl, Hyd Lifters IM, 427, 400, 4 Speed, L36 Engine, Holley 3X2 Carbs IO, 427, 400, THM400 Auto, L36 Engine, Holley 3X2 Carbs IT, 427, 430, M22 4 Speed, Holley 4 Bbl, Special Cam IR, 427, 435, 4 Speed, Mechanical Lifters, Holley 3X2 Carbs IU, 427, 435, 4 Speed, L71 Engine, Aluminum Heads (Also used for L88) Corvette Engine Blocks (You may have a different block, if so it might be from another Chevy Vehicle) 3914660 327ci, 300 HP, 2 Bolt Main 3914678 327ci, 300 & 350 HP, 2 Bolt Main 3916321 427ci, 390 HP, 2 Bolt Main – This block only used until January 1968 3916321 427ci, 400, 430 & 435 HP 4 Bolt Main – This block only used until January 1968 3935439 427ci, 390 HP, 2 Bolt Main – This block made after January 1968 3935439 427ci, 400, 430 & 435 HP, 4 Bolt Main made after January 1968 Cylinder Head 3917291 327ci, 300HP, 1.94 intake 1.50 exhaust 63.305 cc 3917291 same as above with 2.02 intake 1.60 exhaust (late production) 63.305 cc 3917215 427ci, 390 & 400 HP, 2.06 intake 1.72 exhaust oval port 100.967 cc 3919840 427ci, 435 HP, L71 Engine, 2.19 intake 1.72 exhaust 106.8 cc 3919842 427ci, 430 HP (L88) and below 3919842 427ci, 435 HP (L89) 2.19 intake 1.72 exhaust, 106.8 cc Aluminum Head |
do you mind posting the sources you used? thanks
Austin |
Please be aware that the 68 VIN code is 194678S 4 00 000. Not a one. Lou.
Holy “old thread revival” Batman!
Over 13 years. Yikes.
